i need collect the values from the DHT Sensor by HTTP commands http://<espeasyip>/control?cmd=<command> into php
Is there an option like the other way to switch the relais by commands?
DHT Values by http command
Re: DHT Values by http command
You can switch by http request or be MQTT subscription.
Regards,
Regards,
The relais was only written as an example
I need the dht device temperature value as http command
Can you extract the value from http://<IP>/json
Do you want something else?
Regards,
Regards,
Thanks, it works perfect for me
Users browsing this forum: No registered users and 27 guests
