Hi All,
I'm looking at the way strings are handled by the serialsend command. I thought I would be able to escape tabs, newlines and the like and also to encode non-printable characters as \xAA, but everything I try to send is just sent exactly as typed, no parsing. I'm experimenting with trying to control some devices that have bespoke serial command protocols, some of which include non-printable characters and/or need carriage return or tab codes in the message.
Looking at the code in P20.ino, I see that serialsend simply takes the remainder of the line after the "serialsend" bit and sends it to serial.println(), presumably as a string type. This means that serial.println can't interpret any arguments in the remainder of the ESPEasy rule line and just takes it all as a literal ASCII string. That seems to stop it even converting the usual \n, \t, etc.
From P20:
<code>
case PLUGIN_WRITE:
String command = parseString(string, 1);
if (command == F("serialsend"))
success = true;
String tmpString = string.substring(11);
Serial.println(tmpString);
</code>
Is there any way to encode a string within a rule, before then getting that string sent to the serial port?
Or would I have to think about writing a plug-in to handle arbitrary serial data streams? Doesn't seem to difficult (apart from finding the time!)
Rules, string parsing and serialsend
Various D1 & Sonoffs with ESPEasy, some Tasmota. Domoticz, Z-wave.
ESPEasy Patreon - keep up the good stuff, guys!
Users browsing this forum: Bing [Bot] and 3 guests
