ESP EasyDoorbell
mrcage
ESP EasyDoorbell
#1 Post by mrcage » 01 Jun 2018, 20:43
Hi Guys,
I created a simple hack with a cheap doorbell from Grundig.
See this demonstration video on youtube. https://www.youtube.com/watch?v=l9GmqCqmAQ0
I modified 1 receiver and catch the led (hi input) using a wemos esp.
This works brilliant as I forward the status to Openhab which sents me a image by Telegram 8-)
The thing is it receives 5 to 8 hi inputs and sents them as seperate events to openhab (mqtt). I want just one event so I want to aggregate to just one event.
I can try to solve it in openhab using a rule, but it seems there is a rule engine in espeasy as well!
Can someone give me a headstart where to begin or what to do?
BTW, I love this software! it's awesome.
mrcage
Re: ESP EasyDoorbell
#2 Post by mrcage » 09 Jun 2018, 20:48
120 reads and no replies :roll:
Let me rephrase the question.
I receive multiple events from the input (doorbell)
Should I create a rule which writes the status to a variable?
If The variable is set the other events will be skipped.
If (input = HIGH){ #rule1
set variable to 1
sleep 5000
set variable to 0
If (variable = 1){ #rule2
send mqtt message to openhab
should this work? Or can't I overrule that the event is already sent to controller?
danmero
#3 Post by danmero » 09 Jun 2018, 21:05
Use timer to debounce
On [Switch1#switch] do
   TimerSet,9,1
EndOn
On Rules#Timer=9 do
  If [Switch1#switch]=1
    // Do-whatever-you-want here
  EndIf
EndOn
Regards,
