Two BME280s on ESP8266 using ESP Easy
barneylejeune
#1 Post by barneylejeune » 17 Jun 2018, 01:15
What do I need to do to connect to BME280s to the same ESP8266 using ESP Easy? I want to monitor temperature, humidity and pressure both inside and outside and would like to do this by using two BME280s and a single ESP8266. Is this possible?
Re: Two BME280s on ESP8266 using ESP Easy
#2 Post by grovkillen » 17 Jun 2018, 05:10
whatsupskip
#3 Post by whatsupskip » 13 Jul 2018, 00:38
I don't suppose you know who took the pictures of the plastic box/case used in these pictures?
Particularly where was it purchased from.
#4 Post by grovkillen » 13 Jul 2018, 10:14
Yes it's my pictures ;) Here's the box I got>>
HomeJCL
#5 Post by HomeJCL » 13 Jul 2018, 11:54
@Grovkillen
Am I wrong or do these enclosures have a cable hole on top and bottom ?
#6 Post by grovkillen » 13 Jul 2018, 13:07
Not a cable hole per say but yes, holes. The plastic plug in the middle is to fixate the PCB inside the enclosure, not included with the enclosure.
whatsupskip
#7 Post by whatsupskip » 13 Jul 2018, 23:12
Thank you.
I spent over an hour looking for similar cases on Aliexpress and couldn't find any as good value or suitable as this one.
