Hi I wanted to send some of data using SendTo
And its works because I see it in logs on another device with values but I can't display the value on OLED.
Same as I tried to display [Clock#Time] its also not show.
I know %systime% is displayed well, but why some values is possible to display and some not?
I found round up solution putting event to dummy task but I still curious the reason.
Why some kind of events does not show on OLED SSD1306?
Re: Why some kind of events does not show on OLED SSD1306?
In the file StringConverter.ino you can see all the "aliases" made which can be used to create strings.
These are marked with %text%
When using square brackets, you normally address output values from a task.
Typically [name#value] where "name" is the name given to the task (must be unique) and "value" is the name of the value of that task.
Events are typically used to mark a moment in time to trigger a rule to start.
So you would use the event in the rule to start executing a rule.
