ESP8266 entering AP mode when WiFi down
isnogood
#1 Post by isnogood » 07 Jul 2018, 15:05
I recently noticed that when WiFi is switched off or down (during router upgrade or for maintenance) all previously connected ESPs appear as access points on channel 1 (and can be connected provided you know the WPA AP Mode Key).
Is that a bug or a feature? How can that be disabled?
Re: ESP8266 entering AP ode when WiFi down
#2 Post by grovkillen » 07 Jul 2018, 15:30
It's by design but maybe we should have a (lets say) 10 minute delay for it to happen if it was recently connected to a working WiFi.
mrwee
#3 Post by mrwee » 07 Jul 2018, 15:51
An option to define 'fallback' would be even greater. I have no use for AP mode, as all ESP devices are controlled by openhab/MQTT, so if my Wi-Fi goes down, I'd prefer espeasy to try and reconnect continuously.
Maybe if the AP passphrase is left empty, then AP fallback mode is disabled, if it's filled in, then it works with that passphrase. This also avoids the device broadcasting an SSID with a well-known passphrase.
isnogood
Re: ESP8266 entering AP mode when WiFi down
#4 Post by isnogood » 07 Jul 2018, 17:21
I'm also using openhab mqtt. It ist not a real problem, as they reconnect as soon as WiFi is back up again. However I don't like them to appear in the list of available APs during the downtime of WiFi. (my neighbours do not need to know all my ESPs)
enesbcs
#5 Post by enesbcs » 07 Jul 2018, 17:43
isnogood wrote:
07 Jul 2018, 15:05
It is a feature.
You can try to compile and use the Wifiman plugin which is in the playground, and has a killap command, which effectively disables AP mode.
viewtopic.php?f=6&t=2846
https://github.com/letscontrolit/ESPEas ... iFiMan.ino
danmero
#6 Post by danmero » 07 Jul 2018, 17:44
+1 For disable AP mode option once configured or at last hidden SSID(at worst).
Regards,
waspie
#7 Post by waspie » 09 Jul 2018, 14:28
it's quite rare that it happens for me but i did post to join in the laughter when i do a firmware upgrade on my APs and all of a sudden i have 15 extra wifi networks showing up :lol: :lol: :lol: :lol:
avasthisamar
#8 Post by avasthisamar » 20 Mar 2019, 10:16
Its a quite happen problem whenever the wifi is turned off.
Hardware networking
Users browsing this forum: No registered users and 4 guests
