I have a problem with rules. I entered a rule, which was around 1900 characters long, within the 2k limit. It seemed ok for a while, but after a time and a few edits, it was suddenly truncated by the system to 1471 characters, cutting it off in mid-code. I've had this happen on two different modules, same software build. I can't find the cause, but it always involves editing the rule after initial submission.
Is there a known bug, or should I raise this one on the GitHub list? Not sure how helpful it is given I can't yet pin down when it happens and when it doesn't...
Jeff
Build 20102 - Mega
Libraries ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
GIT version mega-20180723
Plugins 71 [Normal] [Testing]
Build Md5 caa8bf1572c476754c51a52fcb6978d5
Md5 check passed.
Build time Jul 23 2018 02:14:42
Binary filename ESP_Easy_mega-20180723_test_ESP8266_4096.bin
Rules being truncated after editing
Various D1 & Sonoffs with ESPEasy, some Tasmota. Domoticz, Z-wave.
ESPEasy Patreon - keep up the good stuff, guys!
Re: Rules being truncated after editing
As far as I can tell - and I have several devices running it - the 20180519-TEST version doesn't have this problem. I've just loaded the older version on the first module that had the truncation problem with the July version and so far, so good. Maybe that will help to isolate the cause.
Yes, known issue. https://github.com/letscontrolit/ESPEasy/issues/1296
Users browsing this forum: Google [Bot] and 2 guests
