Rule help
trumee
Rule help
#1 Post by trumee » 31 Jul 2018, 00:23
I am using MQTT import plugin to read a topic and display its value on OLED. The import works fine but displaying the value of the variable doesnt work,
on motor#ONOFFSTATE do
  if [motor#ONOFFSTATE]>0
     OLEDCMD,on
     OLED,3,1,Motor ON
     OLED,4,1,Motor [motor#ONOFFSTATE]  //DOESNT WORK
     OLED,3,1,Motor OFF
     OLED,1,1, %systm_hm_am%
What is the right way of display MQTT topic in a rule?
Re: Rule help
#2 Post by TD-er » 01 Aug 2018, 22:04
You could try setting it in quotes, like this:
OLED,4,1,"Motor [motor#ONOFFSTATE]"
Problem with rules parsing is that the space is also a parameter separator.
N.B. this quotes feature is added very recently. Not sure if it will work like this, but you could try.
trumee
Re: Rule help
#3 Post by trumee » 05 Aug 2018, 00:39
Unfortunately, that did not work. The error was , Command unknown ". The quotes was not accepted. I am running ESP_Easy_mega-20180804_normal_ESP8266_4096.bin
Re: Rule help
#4 Post by grovkillen » 05 Aug 2018, 09:16
Show us the exact command you tried.
trumee
Re: Rule help
#5 Post by trumee » 12 Aug 2018, 16:28
I am using the following rule,
On System#Boot do    //When the ESP boots, do
OLEDCMD,clear
     OLEDCMD,on
     OLED,2,1,"Motor ON"
     OLED,3,1,"Motor [motor#ONOFFSTATE]"
     OLED,2,1,"Motor OFF"
On switching on the nodemcu I get a single message "MOTOR OFF", I dont get the second line which should say, "MOTOR 0".
Re: Rule help
#6 Post by grovkillen » 12 Aug 2018, 17:10
OLEDCMD,clear
     OLEDCMD,on
     OLEDCMD,2,1,"Motor ON"
     OLEDCMD,3,1,"Motor [motor#ONOFFSTATE]"
     OLEDCMD,2,1,"Motor OFF"
trumee
Re: Rule help
#7 Post by trumee » 14 Aug 2018, 00:35
With your rule i get an error in the log,
6799: EVENT: MQTT#Connected
7154: IMPT : [motor#ONOFFSTATE] : 1.00
7156: EVENT: motor#ONOFFSTATE=1.00
7172: ACT : OLEDCMD,on
7181: ACT : OLEDCMD,2,1,'Motor ON'
7190: ACT : OLEDCMD,3,1,'Motor 1.00'
7208: Command: oledcmd
7208: Command unknown: 'oledcmd'
7355: IMPT : [motor#PRESSURE] : 0.00
7356: EVENT: motor#PRESSURE=0.00
7654: IMPT : [motor#OLEDSTATE] : 1.00
7655: EVENT: motor#OLEDSTATE=1.00
Looking at this page, OLEDCMD only accepts 1 arguement.
Re: Rule help
#8 Post by grovkillen » 14 Aug 2018, 07:13
Ah, sorry.
I will do some testing once I get my own OLED test unit set up.
trumee
Re: Rule help
#9 Post by trumee » 18 Aug 2018, 04:20
@grovkillen, any luck?
Re: Rule help
#10 Post by grovkillen » 18 Aug 2018, 11:59
trumee wrote: 18 Aug 2018, 04:20 @grovkillen, any luck?
Haven't gotten around to test it just yet... sorry! Will try to find time next week.
trumee
Re: Rule help
#11 Post by trumee » 25 Aug 2018, 15:28
@grovkillen ok, looking forward to it.
trumee
Re: Rule help
#12 Post by trumee » 01 Sep 2018, 17:20
Anybody willing to help?
Users browsing this forum: Google [Bot] and 1 guest
