Hi There,
been using ESP's for a while now as started with Sonoff devices and quickly flashed to Tasmota and set up Domoticz.
grabbed a pile of nodeMCU with motor shields for additional projects and have finally found a need when I killed the controller on my home made LED aquarium lighting so after realising the PWM on the ESP wasn't good enough added a PCA9685 and sat down to figure out how I can make it all work......
enter ESP Easy
so far I have to say its looking really good. connecting to the PCA9685 was a breeze and if I am understanding correctly then I should be able to set up timers with rules so keep up the great work and I suspect I will be back soon with some questions
Hi from new UK user
Re: Hi from new UK user
thank you very much.
I was hoping so but have so far had a simple setup and a frustrating 4 hours not getting what should be a simple rule to work.....
I really hope I am missing something obvious but at this rate the love affair could be over before it starts.
The possibilities are great if it works but I am getting weird outputs and the logs not showing anything helpful other than 0+5=0
time for a large G&T I think
Where did you post the rules? I wish to help.opentoideas wrote: ↑21 Sep 2018, 21:04 thank you very much.
Hi, thank you, posted in viewtopic.php?f=6&t=5838
any help would be great as i think i must be nearly there but head is getting scrambled now
