ewaldharmsen
#1
Post
by ewaldharmsen » 03 Sep 2018, 09:12
Using the latest build, I cannot get my Sonoff SV to get to work.
The latest esp easy version (147) works without a problem.
I get this error:
INIT : Booting version: mega-20180903 (ESP82xx Core 00000000, NONOS SDK 2.2.1(cf d48f3), LWIP: 2.0.3)
94 : INIT : Warm boot #10 - Restart Reason: Exception
98 : FS : Mounting...
103 : FS : Mount successful, used 75802 bytes of 113201
391 : CRC : program checksum ...OK
397 : CRC : SecuritySettings CRC ...OK
398 : CRC : binary has changed since last save of Settings
417 : INIT : Free RAM:28608
418 : INIT : I2C
418 : INIT : SPI not enabled
432 : INFO : Plugins: 46 [Normal] (ESP82xx Core 00000000, NONOS SDK 2.2.1(cfd48f 3), LWIP: 2.0.3)
433 : WIFI : No valid wifi settings
433 : WIFI : Could not connect to AP!
437 : WIFI : Set WiFi to AP
Exception (29):
epc1=0x4000e1c3 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000018 depc=0x00000 000
ctx: cont
sp: 3ffffbf0 end: 3fffffd0 offset: 01a0
>>>stack>>>
3ffffd90: 0104a8c0 00000010 00000001 40262c04
3ffffda0: 0104a8c0 00ffffff 0104a8c0 40259a1c
3ffffdb0: 00ffffff 0104a8c0 0000000a 3ffea7af
3ffffdc0: 0104a8c0 00000001 00000010 00000002
3ffffdd0: 0104a8c0 00ffffff 3fff2f88 0000000a
3ffffde0: 00000000 40106e14 3ffea4b8 401004e8
3ffffdf0: 402701ce 3fff460c 402a7340 40106e14
3ffffe00: 4027dd61 00000017 60000200 4027dd86
3ffffe10: 3ffea4b8 4026b42b 3fff460c 3fff5b2c
3ffffe20: 40270496 3fff460c 3fff5b2c 00000000
3ffffe30: 0000000a 3ffef060 3ffeefdc 3ffef24c
3ffffe40: 00000000 4027e41f 3ffeefdc 3fff5b2c
3ffffe50: 00000018 3fff1b8f 00000002 3fff1b8f
3ffffe60: 402a7388 00000064 3ffffe98 4026bb25
3ffffe70: 3ffeefdc 3fff5b2c 3fff1b8f 3ffe84e4
3ffffe80: 00000064 4026bb0c 3fff5b2c 3fff1b8f
3ffffe90: 207fcf5e 0000cb29 00000000 00000000
3ffffea0: 00000000 00000000 00000000 00000000
3ffffeb0: 00000000 00000000 00000000 00000000
3ffffec0: 00000000 00000000 00000000 4026cec3
3ffffed0: 3fff5b2c 00000002 00000002 4026cf10
3ffffee0: 00000000 3ffef060 3ffefe88 00000000
3ffffef0: 402830c1 00000002 00000002 00000002
3fffff00: 40283227 00000002 00000002 402831db
3fffff10: 00000000 00000000 00000000 3fff568c
3fffff20: 402832fe 00000002 00000002 00000000
3fffff30: 40208ea2 00000000 00000000 00000000
3fffff40: 4029c1cf 00000001 3ffe85e8 3fff29e8
3fffff50: 3fff1b8f 3fff04ee 00000002 40231315
3fffff60: 4029c18b 3ffe85e8 00000001 40231506
3fffff70: 3fff1b8f 3ffe85e8 3fff1e70 402317ae
3fffff80: 3fff1b8f 3ffe85e8 3fff1e70 4025044b
3fffff90: 00000000 00000000 00000000 40257b98
3fffffa0: 3fff467c 0000006f 0000005a feefeffe
3fffffb0: 3fffdad0 00000000 3fff29de 40255db8
3fffffc0: feefeffe feefeffe 3ffe87ac 40100721
<<<stack<<<
last failed alloc call: 40106E14(1073652920)
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v00000000
~ld
▒U93 :
Post
by grovkillen » 03 Sep 2018, 09:26
How did you do the update?
ewaldharmsen
#3
Post
by ewaldharmsen » 04 Sep 2018, 11:18
I did it via serial, tried 4 different methods of applying it: DOUT, etc.
Post
by grovkillen » 04 Sep 2018, 11:58
A blank flash prior to the real flash as well?
ewaldharmsen
#8
Post
by ewaldharmsen » 07 Sep 2018, 09:49
Thank you very much, first using the blank solved my problem!
Post
by grovkillen » 07 Sep 2018, 10:51
Great!
ewaldharmsen
#10
Post
by ewaldharmsen » 01 Oct 2018, 11:26
but I now have the same problem on a Sonoff basic...
I received it by mail and flashed the latest version of ESP easy on, the unit keeps rebooting.
On the Sonoff Dual which I received on the same time, it works fine.
Flashing it with a blank does not help.
Flashing it with ESP 148 does work...
Post
by TD-er » 01 Oct 2018, 12:43
What is your latest version tested? 20180930 ?
ewaldharmsen
#12
Post
by ewaldharmsen » 01 Oct 2018, 17:30
I tried several, including 20181001.
I get this:
RESET: Resetting factory defaults...
RESET: Warm boot, reset count: 3
RESET: Too many resets, protecting your flash memory (powercycle to solve this)
Exception (0):
epc1=0x4000e25d epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff3470 end: 3fff3720 offset: 01a0
>>>stack>>>
3fff3610: 00000000 3fff11ac 3fff11ac 40258c44
3fff3620: 3fff388c 00000283 00000283 3fff3730
3fff3630: 3fff263c 0000004f 3fff263c 402575e0
3fff3640: 00000009 001064c0 3fff3798 4025793d
3fff3650: 3ffe9071 3fff3798 3ffe87b4 00000000
3fff3660: 3fff42a4 402031e2 00000100 401004e8
3fff3670: 40203186 00000100 00000001 40203291
3fff3680: 00000000 0000001c 00000003 3fff584c
3fff3690: 3fff1875 3fff3730 3fff263c 3fff3730
3fff36a0: 3fff1875 00000001 3fff263c 402576c0
3fff36b0: 00000000 0000001c 00000000 40203026
3fff36c0: 402022ae 3fff263c 3fff1b84 40213139
3fff36d0: 3fff1875 3fff263c 3fff1b84 40247314
3fff36e0: 00000000 00000000 00000000 4025b65c
3fff36f0: 3fff59ec 0000006f 0000002f feefeffe
3fff3700: 3fffdad0 00000000 3fff26f6 40259874
3fff3710: feefeffe feefeffe 3ffe87b4 40100721
<<<stack<<<
ets Jan 8 2013,rst cause:1, boot mode:(3,0)
tail 8
chksum 0x2d
csum 0x2d
v00000000
~ld
▒URESET: Resetting factory defaults...
Post
by TD-er » 01 Oct 2018, 22:27
Can you see what brand flash chip is used?
Or get the vendor ID of the flash chip when looking with a tool like esptool:
https://github.com/espressif/esptool
ewaldharmsen
#14
Post
by ewaldharmsen » 27 Oct 2018, 17:50
I have the same problem with a S26 device some more information:
Chip ID: 0x00181536
Manufacturer: 85
Device: 6014
Detected flash size: 1MB
ewaldharmsen
#15
Post
by ewaldharmsen » 29 Oct 2018, 09:17
A I completely missed the puma release, just tested that this morning, and it works!
Now just waiting for a stable release of that one.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 10 guests
