Hello all,
i am just wondering my DHT11 shows up the values only as Integer and not as expected as float.
it is always x.0 instead of x.>=0
i use the new image 20181004
Thanks for your help
Sascha
DHT11 shows integer values instead of float
- Sasch600xt
Re: DHT11 shows integer values instead of float
What is your settings? Decimal points?
- Sasch600xt
i used 2 dezimal points
Then it might be a bug. Please report it on GitHub.
- Sasch600xt
Here is a screenshot of my settings
- Screenshot 2018-10-04 17.08.47.png (89.87 KiB) Viewed 3829 times
- Sasch600xt
ok, i will
Thank you
Thank you
- Sasch600xt
Just for others with the same problem:
The DHT11 is a hardware 8bit device.
So there is no float value to be expected.
I use a DHT22 now which can be configured to 9,10,11,12 bit resolution.
So my "problem" was just a hardware limitation of the DHT11.
Nothing wrong with ESPEasy here.
Greetz
Sascha
Greetz
Sascha
Users browsing this forum: No registered users and 43 guests
