I got the latest built running with the following setup:
DEVICES:
8 x PCF8574 switch input (120 s interval)
2 x ADS1115 ADC (120 s interval)
1 x SYSTEM IUnfo UPTIME (120 s interval)
CONTROLLER:
2 x FHEM HTTP
The problem is, that not all devices are sent to the controllers.
The last 3 in the list are not sent.
I suspect it has to do with queues and timeouts while sending to the controllers because when i disable one controller, it works perfectly.
Can anybody give me a hint how to solve the problem and what settings i should use in queues etc.?
[solved] Some devices ignored when using 2 controllers - queue issues?
Re: Some devices ignored when using 2 controllers - queue issues?
What settings are you using right now?
I was using the default settings.
Another modul with 12 DS18B20 sensors shows the same behaviour.
Meanwhile i played around and found the following settings to work:
Minimum Send Interval: 100 ms
Max Queue Depth: 25
Max Retries: 10
Full Queue Action: Delete oldest
Check Reply: Ignore Ack
Client Timeout: 1000 ms
However i am not sure if these are recommended.
Max Queue Depth: 25
Max Retries: 10
Bump the send interval to 1000mSec and try. If that works you could optimize by lowering it by 100mSec until you find the "perfect" level.
I think this was your fix:
Max Queue Depth: 25
The queue is the number of samples to keep waiting to be sent.
When a lot of values are sent in a burst, you may want to increase this queue depth to fit all.
Max Queue Depth: 25
Thank you both, problem is solved
