WiFi Button with ModemSleep
enesbcs
#1 Post by enesbcs » 31 Oct 2018, 15:16
I found the Button project and slightly revised. I have added a 0.8-3.3 to 3.3VDC step-up converter to it with 2xAAA battery. (can be done with a 1.8-5.5V to 3.3V Step up-down converter + 3xAAA battery) - update: the small step-up converter i have used is unable to provide enough power for the ESP when the voltage drops below 2.5V :( it's useless.
Also the original project uses some LUA interpreter, i uploaded ESPEasy to it.
The full project costs approximately $6.
From the outer world, it looks like any other touch light.
Inside:
Wiring:
ESPEasy devices:
Rules example for using with ModemSleep after each buttonpress:
on System#Boot do
 taskvalueset,5,1,0
 taskvalueset,5,2,0
 timerset,2,120
on gomb#Shortpress do
 taskvalueset,5,1,127
 event,wakeup
on gomb#Longpress do
 taskvalueset,5,1,128
 event,wakeup
on wakeup do
 taskvalueset,5,2,1
 If [wifiman#Connected]>0
  event,evalbtns
  modemsleep,0
on evalbtns do
 taskrun,3
 if [glob#idx]>0
  Publish domoticz/in,{"idx":[glob#idx],"nvalue":1.00,"svalue":"On", "RSSI": [rssi#rssi]}
  pulse,13,1,100
  Publish domoticz/in,{"idx":[glob#idx],"nvalue":0.00,"svalue":"Off", "RSSI": [rssi#rssi]}
 timerset,1,1
on MQTT#Connected do
 event,evalbtns
on Rules#Timer=1 do
 if [glob#sleepok]>0
  modemsleep,1
 if [glob#idx]=127
  pulse,13,1,200
 if [glob#idx]=128
  pulse,13,1,500
 taskvalueset,5,1,0
on Rules#Timer=2 do
 taskvalueset,5,2,1
Project page
Re: WiFi Button with ModemSleep
#2 Post by grovkillen » 31 Oct 2018, 15:35
OOOOOH, sweet! I want to have this featured on the upcoming home page :)
enesbcs
#3 Post by enesbcs » 31 Oct 2018, 16:03
grovkillen wrote: 31 Oct 2018, 15:35 OOOOOH, sweet! I want to have this featured on the upcoming home page :)
Waoh a new page is under development? :) Thanx, I feel honored.
In the matter of fact, i have a lot of ESP projects, but i am too lazy to translate it... i'll start once. :)
