I managed to get the CCS811 (on the cjmcu-8118 board) working with ESPeasy-mega. I use the wemos d1 mini and compiled the ESPEasy with the _P118_CCS811.ino plugin on the ArduinoIDE. I use Domotiz to follow the data and look at the trend. I also use a DHT11 to get the temperature and moisture readings to compensate.
When I power up the sensor the first reading is 400ppm. It slowly goes up and gets up to a relative stable value , but after a couple of hours the data freezes and when I check the espeasy log it reads 'CCS811 : No values found'. Only solution is power off and on. I tried different reading times and interval, but no improvement.
Anyone a suggestion on how to tackle this?
CCS811 CO2 sensor
Re: CCS811 CO2 sensor
Same problem here, i used tasmota, got the same error after 6hs.
Some more googling revealed the possibility that the freezing is caused by the I2c clockstretching issue between the CCS811 and the Wemos. In the ESPEasymega version I use there is in the advanced section the setting I2c clockstretchlimit. I could not find anything on this parameter. The CCS requires a clockstretch value of '500'. Not sure how that works with the limit parameter. Anyone a hint?
I did tried the clock strech limit setting in the advanced section of the ESPEasy-mega and chnaged the 0 to 460 and that did the trick. The sensor is running for 2.5 days already. There are a few ' no values found' errors, but they do not stop the unit from working. Hope this helps others with similar issues.
