Shelly Wifi operated relay switch
Hi all,
any idea how to get nice wifi relay switch into ESP Easy which will perfectly fit into wall mount inside existing wall switch?
https://shelly.cloud/product/shelly-1-open-source/
Or at least into domoticz
Vojta
Vojta
Re: Shelly Wifi operated relay switch
Many users have flashed and operate the shelly1 with ESP Easy
Shelly stock firmware also works with Domoticz with a python plugin:vojtishek wrote: ↑05 Nov 2018, 12:44 https://shelly.cloud/product/shelly-1-open-source/
https://github.com/enesbcs/Shelly_MQTT
Otherwise there are a simple ESP8266 inside with 2MB flash, you can flash ESPEasy to it.
Thanks guys, really quick answers.
I'm going to buy them
We even ship a custom firmware file with our nightly releases.
hi, why shelly is not anymore included in the latest version of releases??grovkillen wrote: ↑05 Nov 2018, 15:21 We even ship a custom firmware file with our nightly releases.
i take the opportunity to ask the difference between the "standard" ( ESP_Easy_mega-20181117_normal_ESP8266_1024) vs:
ESP_Easy_mega-20181117_normal_core_241_ESP8266_1024
ESP_Easy_mega-20181117_test_ESP8266_4096_VCC
ESP_Easy_mega-20181117_minimal_ESP8266_1024_OTA
ESPEasy_2step_UploaderMega_1024
and last question: why there is no more the PUYA build for sonoff basic marked on pcb "Sonoff Basic R2 v1.0 2017-10-11" ??
thanks
Shelly should be part of the release. If not we need to fix it.
Special PUYA builds are not needed anymore. Thanks to uzi18 we now have a dynamic patch which is applied on all builds. So no need for special versions.
all shelly products are build on ES8266?
Regards,
MiKa
Regards,
MiKa
Yes but 2M memory.
no, i do not see shelly inside the last build...grovkillen wrote: ↑20 Nov 2018, 06:01 Shelly should be part of the release. If not we need to fix it.
and related to difference from the "standard version" and those:
thanks
Have someone pictures from inside of this modules?
Shelly1:
esptool.py v2.0.1
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Manufacturer: ef
Device: 4015
Detected flash size: 2MB
Hard resetting...
Shelly1: (ESP8266EX based)
Shelly2: (ESP8266EX based)
Shelly4: (not ESP based!)
Some other pictures...
Thanks for pictures
I thing upgrade to 4MB will be just for few cents
https://www.ebay.com/itm/10pcs-W25Q32FV ... 2749.l2649
Regards,
MiKa
Regards,
MiKa
