Hi! I have 2 Sonoff 4CH Pro R2 devices. I have flashed them. One with tasmota firmware , the second with ESP EASY. Both times the flashing procedure was success. Setup procedure was also success, devices were working well till first reboot. After reboot I have 3 leds on and nothing more. Both devices bricked. I can't connect to device, can't flash (but one time after severasl probs I could read the flash, but can't repeat flashing procedure anymore) .
What have I done wrong?
I've flashed last release ESP Easy https://github.com/letscontrolit/ESPEasy/releases
I've used python esptool with this parameters:
esptool.py --port COM3 write_flash -fs 1MB -fm dout 0x0 ESP_Easy_mega-20181110_normal_ESP8285_1024.bin
I have an experience , I've flashed some Sonnof Basic with success.
I've red about the same result (bricked devices with 3 leds). Maybe my devices were broken ? (but they worked well with original firmware). Maybe Pro R2 device can't be flashed with non original flash? Does anybody had the same problems?
Sonoff 4CH Pro R2 bricks after flashing
Re: Sonoff 4CH Pro R2 bricks after flashing
I have two Sonoff 4CH (I'm not next to them at the moment so can't remember for sure) ; I put on the 8286_1024.bin, not the 8285_1024.bin build. Now next to it:
Firmware
Build 20102 - Mega
Libraries ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
GIT version mega-20180507
Plugins 47 [Normal]
Build Md5 aef3b5327f73e5db60c1d3c8aeadc4
Md5 check passed.
Build time May 7 2018 02:03:47
Binary filename firmware.bin
Firmware
Build 20102 - Mega
Plugins 47 [Normal]
Md5 check passed.
After one week my first Sonoff 4Ch Pro R2 has back to the life! He hasn't worked for a week. I did nothing. It's a some magic!
I was flashing it with 8285_1024.bin
But I have another one from the same party. It's dead with 3 lamps always on. Most likely it's defective.
Try erase flash.
esptool.py --port COM3 erase_flash
I flashed my Sonoff 4ch PRO by this instructions first and then with And it made him turn on with the same 3 lamps!
Ater flash use factory reset button with pre-defined config "Sonoff 4ch".
Yes 3 relays and 3 lamps is swithed on at boot, it seems like a small bug, maybe because two chips ESP8285 + STM32 is used onboard.
I solved it for me by adding rule on boot and swithed on all relays booth:
These corrections in the default rules can make the button always sensitive when first pressed, regardless of the state of the relay:
esptool.py --port COM5 erase_flash
esptool.py --port COM5 write_flash 0x00000 ESP_Easy_mega-20190216_normal_ESP8285_1024.bin
on System#Boot do
gpio,12,1
gpio,5,1
gpio,4,1
gpio,15,1
on Button1#switch do
if [Relay1#switch]=0
gpio,12,1
gpio,12,0
on Button2#switch do
if [Relay2#switch]=0
gpio,5,1
gpio,5,0
on Button3#switch do
if [Relay3#switch]=0
gpio,4,1
gpio,4,0
on Button4#switch do
if [Relay4#switch]=0
gpio,15,1
gpio,15,0
I flashed the CH4 Pro R2 today with the ESP_Easy_mega-20190305_normal_ESP8285_1M image and still has the same issue: After boot relais 1, 2, and 3 are turned on. Looking at the debug 4 logs on the TTL console I see the following
So somehow the GPIO events for the relais switches are being fired for no apparent reason as it seems.
Any pointers someone? I would like to have the default state off for the 4 channels, but setting them on the System#Boot like
is handled before the spontaneous events for GPIO 12, 5, and 4 occur. Any pointers?
cheers,
Martijn
660 : EVENT: System#Boot
937 : SW : GPIO=9 State=1 Output value=1
945 : EVENT: button2#state=1.00
1020 : ACT : gpio,5,1
1024 : SW : GPIO 5 Set to 1
1106 : SW : GPIO=10 State=1 Output value=1
1115 : EVENT: button3#state=1.00
1203 : ACT : gpio,4,1
1206 : SW : GPIO 4 Set to 1
1272 : SW : GPIO=12 State=1 Output value=1
1279 : EVENT: relais1#state=1.00
1409 : SW : GPIO=5 State=1 Output value=1
1416 : EVENT: relais2#state=1.00
1543 : SW : GPIO=4 State=1 Output value=1
1551 : EVENT: relais3#state=1.00
2200 : WD : Uptime 0 ConnectFailures 0 FreeMem 23688 WiFiStatus 0
on system#boot do
debug 4
gpio,12,0
gpio,5,0
gpio,4,0
gpio,15,
cheers,
Martijn
Users browsing this forum: No registered users and 41 guests
