Shelly Wifi operated relay switch
vojtishek
#1 Post by vojtishek » 05 Nov 2018, 12:44
Hi all,
any idea how to get nice wifi relay switch into ESP Easy which will perfectly fit into wall mount inside existing wall switch?
https://shelly.cloud/product/shelly-1-open-source/
Or at least into domoticz :)
Vojta
Re: Shelly Wifi operated relay switch
#2 Post by grovkillen » 05 Nov 2018, 12:48
Many users have flashed and operate the shelly1 with ESP Easy
enesbcs
#3 Post by enesbcs » 05 Nov 2018, 13:42
vojtishek wrote: 05 Nov 2018, 12:44 https://shelly.cloud/product/shelly-1-open-source/
Shelly stock firmware also works with Domoticz with a python plugin:
https://github.com/enesbcs/Shelly_MQTT
Otherwise there are a simple ESP8266 inside with 2MB flash, you can flash ESPEasy to it.
vojtishek
#4 Post by vojtishek » 05 Nov 2018, 14:06
Thanks guys, really quick answers.
I'm going to buy them :)
#5 Post by grovkillen » 05 Nov 2018, 15:21
We even ship a custom firmware file with our nightly releases.
megamarco83
#6 Post by megamarco83 » 19 Nov 2018, 23:51
grovkillen wrote: 05 Nov 2018, 15:21 We even ship a custom firmware file with our nightly releases.
hi, why shelly is not anymore included in the latest version of releases??
i take the opportunity to ask the difference between the "standard" ( ESP_Easy_mega-20181117_normal_ESP8266_1024) vs:
ESP_Easy_mega-20181117_normal_core_241_ESP8266_1024
ESP_Easy_mega-20181117_test_ESP8266_4096_VCC
ESP_Easy_mega-20181117_minimal_ESP8266_1024_OTA
ESPEasy_2step_UploaderMega_1024
and last question: why there is no more the PUYA build for sonoff basic marked on pcb "Sonoff Basic R2 v1.0 2017-10-11" ??
thanks
#7 Post by grovkillen » 20 Nov 2018, 06:01
Shelly should be part of the release. If not we need to fix it.
Special PUYA builds are not needed anymore. Thanks to uzi18 we now have a dynamic patch which is applied on all builds. So no need for special versions.
MiKa1975
#8 Post by MiKa1975 » 20 Nov 2018, 06:16
all shelly products are build on ES8266?
Regards,
MiKa
#9 Post by grovkillen » 20 Nov 2018, 06:25
Yes but 2M memory.
megamarco83
#10 Post by megamarco83 » 20 Nov 2018, 10:53
grovkillen wrote: 20 Nov 2018, 06:01 Shelly should be part of the release. If not we need to fix it.
no, i do not see shelly inside the last build...
and related to difference from the "standard version" and those:
thanks
MiKa1975
#11 Post by MiKa1975 » 20 Nov 2018, 10:56
grovkillen wrote: 20 Nov 2018, 06:25 Yes but 2M memory.
Have someone pictures from inside of this modules? ;)
enesbcs
#12 Post by enesbcs » 20 Nov 2018, 20:51
MiKa1975 wrote: 20 Nov 2018, 10:56
Shelly1:
esptool.py v2.0.1
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Manufacturer: ef
Device: 4015
Detected flash size: 2MB
Hard resetting...
Send me a photo camera and i will do some picture.. :) As long as this happens, my phone can produce the following pictures.
Shelly1: (ESP8266EX based)
Shelly2: (ESP8266EX based)
Shelly4: (not ESP based!)
Some other pictures...
MiKa1975
#13 Post by MiKa1975 » 21 Nov 2018, 05:59
Thanks for pictures ;)
I thing upgrade to 4MB will be just for few cents ;)
https://www.ebay.com/itm/10pcs-W25Q32FV ... 2749.l2649
Regards,
MiKa
