Variables for use in rules??
bastibasti
#1 Post by bastibasti » 09 Jan 2019, 21:19
I'm trying to do something like this
(its a simple dimmer, a push button increases a variable, and the pwm output is set according to one of the 5 available dimmer levels)
on button#switch do
  if [button#switch]=0
   $a=$a+1
  if $a=5
   $a=0
 if $a=0
  pwm,2,1024,750
 if $a=1
  pwm,2,1000,750
 if $a=2
  pwm,2,800,750
 if $a=3
  pwm,2,500,750
 if $a=4
  pwm,2,0,750
any idea how to achieve this??
Domosapiens
Re: Variables for use in rules??
#2 Post by Domosapiens » 09 Jan 2019, 21:25
In rules you can use the command let
let,1,10 this will assign the value 10 to %v1%.
To get the value of %v1%, you can use %v1% or [VAR#1] depending on the rule syntax:
if %v1%=10
or
taskvalueset,1,1,%v1%
or
taskvalueset,1,1,[VAR#1]
Jackill
#3 Post by Jackill » 11 Jan 2019, 01:28
Domosapiens wrote:
09 Jan 2019, 21:25
WOW!
Great info! Searched for it resultless..
Where did you find the list of commands to use in rules?
#4 Post by grovkillen » 11 Jan 2019, 05:35
I'm doing my best but need to work on my daytime job too. But the commands are found here: https://espeasy.readthedocs.io/en/lates ... mmand.html
Not all are listed, I will do my best adding them but I don't have the the time just now.
Domosapiens
#5 Post by Domosapiens » 11 Jan 2019, 10:06
While reading the forum, I collect snippets of Rules as examples in a document.
The (new) "Let" statement one was found here:
viewtopic.php?f=4&t=5961&p=32580&hilit= ... ill#p32580
Jackill
#6 Post by Jackill » 11 Jan 2019, 14:44
grovkillen wrote:
11 Jan 2019, 05:35
Shure. This is not even discussed, daytime job on first place.
Nevertheless, system variables can save much.
Face this when I had to do calculations for my solar heating system.
Code like this: "if [Boiler#Temp]<[Solar#Temp]+5 <do smthng> endif" not worked, it need to be passed thru dummy (taskValueSet).
Now I'll save 1 of 12 tasks.
Domosapiens wrote:
11 Jan 2019, 10:06
Good practice! I will put into service.
bastibasti
#7 Post by bastibasti » 14 Jan 2019, 12:11
any idea how to increment a value?
let 1,%v1%+1??
#8 Post by grovkillen » 14 Jan 2019, 13:45
Let,1,[VAR#1]+1
