NTP not working
linasg
NTP not working
#1 Post by linasg » 02 Aug 2016, 10:45
I try to work with 108 and 115 ver. but still my NTP qere didn't get time from NTP server.
I think all my setings is corect IP: 192.168.20.100/GW"192.168.20.1/SM:255.255.255.0/DNS:212.59.1.1
NTP enabled. But system time is looks like start time...
Also I tried different NTP Hostnames but still nothing...
Wher can be problem....
Thank You.
Yves911
Re: NTP not working
#2 Post by Yves911 » 02 Aug 2016, 16:01
Works fine here with server 0.rhel.pool.ntp.org
ManS-H
Re: NTP not working
#3 Post by ManS-H » 02 Aug 2016, 17:51
linasg wrote:Hello
Thank You.
I work with this one: europe.pool.ntp.org
Works fine for me.
costo
Re: NTP not working
#4 Post by costo » 02 Aug 2016, 23:34
linasg wrote:Hello
Thank You.
Some time ago I had NTP issues.
see http://www.esp8266.nu/forum/viewtopic.php?f=6&t=1683
Maybe this helps you find the problem.
linasg
Re: NTP not working
#5 Post by linasg » 03 Aug 2016, 13:59
I tried both servers, NTP still does not work .
My settings are as follows (See pictures)
What am I doing wrong?
Thank You
ManS-H
Re: NTP not working
#6 Post by ManS-H » 03 Aug 2016, 16:24
linasg wrote:I tried both servers, NTP still does not work .
Thank You
Try to leave the optional settings of ESP empty and fill the SSID and the WPAKey, maybe that is the problem.
And i see that yoy have filled, Timezone Offset: (Minutes) with 1 minute. I believe that's not correct but it works. I checked it by my ESP :D
linasg
Re: NTP not working
#7 Post by linasg » 03 Aug 2016, 17:30
In real the SSID and WPA key is to filled, Timezone Offset: I tried set 0; 1; 120 min but still nothing
ManS-H
Re: NTP not working
#8 Post by ManS-H » 03 Aug 2016, 17:43
linasg wrote:In real the SSID and WPA key is to filled, Timezone Offset: I tried set 0; 1; 120 min but still nothing
Your ESP DNS: 212.59.1.1 is that correct?
Is't not 192.168.20.1 ?
Try 192.168.20.1 that is for me the only thing whats different with my settings.
linasg
Re: NTP not working
#9 Post by linasg » 04 Aug 2016, 13:36
No, it not hepl...
Yves911
Re: NTP not working
#10 Post by Yves911 » 05 Aug 2016, 15:00
I have the impression that your ESP doesn't reach the Internet.
Can you try to setup it using DHCP instead of assign it an ip
homerruma
Re: NTP not working correct for my
#11 Post by homerruma » 12 Jan 2019, 14:56
Imagentp by homerruma3, on Flickr
How can I fix this?
Re: NTP not working
#12 Post by grovkillen » 12 Jan 2019, 15:09
Do you have the NTP offset correctly setup? (Found in the advanced page under tools)
homerruma
Re: NTP not working
#13 Post by homerruma » 12 Jan 2019, 15:13
Imagentp1 by homerruma3, on Flickr
Re: NTP not working
#14 Post by grovkillen » 12 Jan 2019, 15:21
Are you german? Then you should have a offset of 60 minutes.
homerruma
Re: NTP not working
#15 Post by homerruma » 12 Jan 2019, 15:25
Serbia
Thank you solved.
Imagentp4 by homerruma3, on Flickr
Imagentp3 by homerruma3, on Flickr
