new ESP.EASY.Flasher Error
Hi!
First this is an great pice of Software, thanks for it!
With the new flasher I get an Error:
"ERROR in : ESP.Easy.Flasher.exe Line: 65 -(1:1) Unquoted String in JSON data only valid for Dictionary names."
Do you have any solution for this?
Next Thing is, I want to Flash ESP32, you wrote that it can be done with Python Script, where can i finde this script and how to use it?
Hary from Vienna
Hary from Vienna
- Unbenannt.jpg (20.14 KiB) Viewed 5146 times
Re: new ESP.EASY.Flasher Error
I guess the API kicked you out. Did it happen the first time you started the software?
Official ESP32 tool is found here http://iot-bits.com/esp32/esp32-flash-d ... -tutorial/
Same situation here.
I received the same error message. Tested new build (09-01-2019 and 10-01-2019) with flasher 0.04.000 on 2 different PC. Both on Win 10 Corp "N" LTSB.
Flasher v0.02.003 works fine.
I'm ready to test. Any instructions..
Same problem for me on Win7 64bits when application start.
Older version is ok.
Please give me exact information about when this error kicks in.
Is it straight of launch of app? Does it always give this error. How many times have you tried?
"Is it straight of launch of app? " -> Yesgrovkillen wrote: ↑12 Jan 2019, 14:37 Please give me exact information about when this error kicks in.
"Does it always give this error ?" -> Always
"How many times have you tried?" -> Many, many, many times
When cliking "OK" button, the same error come back with new number of line.
Line number is always in this order : 65, 67, 72, 194, 198, 49, 49, 49, 49, etc.. until click abort button for exiting app.
Could someone with this problem test this release?
https://github.com/Grovkillen/ESP_Easy_ ... g/0.04.001
If the API limit is hit it will show a warning but it will not try to parse the json messages.
I get same error. Difirence - now it starts report from 71's line, not 65.
Tried 10 times.
Seems this message appear after the app scans for USB COM ports, after it print "No active com ports found!"
When some USB-COM adapter is plugged, app crashes after it finds COM port adaptor.
Okay, will look through it again. Thanks for the feedback!
Same for me, tries multiple times, Always same Error. OS= Win10 x64. Thanks for the link to ES32 Forum
Are you online when trying the app?
Bingo!
When starting flasher with network enabled and internet connection online - it crashes always.
When I try to start it with network disabled - it starts well.
Okay so I will need to fetch that error then. Thanks for the feedback! Much appreciated, new version will arrive tomorrow.
This should now be fixed: https://github.com/letscontrolit/ESPEasy/pull/2238
Hi grovkillen,
It's OK for me for new version TAG 0.04.001
Many thanx.
Many thanx.
Thanks for the info.
Users browsing this forum: Bing [Bot] and 16 guests
