new ESP.EASY.Flasher Error
haryt
#1 Post by haryt » 12 Jan 2019, 09:31
Hi!
First this is an great pice of Software, thanks for it!
With the new flasher I get an Error:
"ERROR in : ESP.Easy.Flasher.exe Line: 65 -(1:1) Unquoted String in JSON data only valid for Dictionary names."
Do you have any solution for this?
Next Thing is, I want to Flash ESP32, you wrote that it can be done with Python Script, where can i finde this script and how to use it?
Hary from Vienna
Re: new ESP.EASY.Flasher Error
#2 Post by grovkillen » 12 Jan 2019, 10:21
I guess the API kicked you out. Did it happen the first time you started the software?
Official ESP32 tool is found here http://iot-bits.com/esp32/esp32-flash-d ... -tutorial/
Jackill
#3 Post by Jackill » 12 Jan 2019, 13:47
Same situation here.
I received the same error message. Tested new build (09-01-2019 and 10-01-2019) with flasher 0.04.000 on 2 different PC. Both on Win 10 Corp "N" LTSB.
Flasher v0.02.003 works fine.
I'm ready to test. Any instructions..
Civodul
#4 Post by Civodul » 12 Jan 2019, 14:16
Same problem for me on Win7 64bits when application start.
Older version is ok.
#5 Post by grovkillen » 12 Jan 2019, 14:37
Please give me exact information about when this error kicks in.
Is it straight of launch of app? Does it always give this error. How many times have you tried?
Civodul
#6 Post by Civodul » 12 Jan 2019, 15:13
grovkillen wrote: 12 Jan 2019, 14:37 Please give me exact information about when this error kicks in.
"Is it straight of launch of app? " -> Yes
"Does it always give this error ?" -> Always
"How many times have you tried?" -> Many, many, many times :)
When cliking "OK" button, the same error come back with new number of line.
Line number is always in this order : 65, 67, 72, 194, 198, 49, 49, 49, 49, etc.. until click abort button for exiting app.
#7 Post by grovkillen » 12 Jan 2019, 17:14
Could someone with this problem test this release?
https://github.com/Grovkillen/ESP_Easy_ ... g/0.04.001
If the API limit is hit it will show a warning but it will not try to parse the json messages.
Jackill
#8 Post by Jackill » 13 Jan 2019, 05:11
grovkillen wrote: 12 Jan 2019, 17:14 Could someone with this problem test this release?
I get same error. Difirence - now it starts report from 71's line, not 65.
Tried 10 times.
Seems this message appear after the app scans for USB COM ports, after it print "No active com ports found!"
When some USB-COM adapter is plugged, app crashes after it finds COM port adaptor.
#9 Post by grovkillen » 13 Jan 2019, 07:21
Okay, will look through it again. Thanks for the feedback!
haryt
#10 Post by haryt » 14 Jan 2019, 09:08
Same for me, tries multiple times, Always same Error. OS= Win10 x64. Thanks for the link to ES32 Forum
#11 Post by grovkillen » 14 Jan 2019, 09:25
haryt wrote: 14 Jan 2019, 09:08 Same for me, tries multiple times, Always same Error. OS= Win10 x64. Thanks for the link to ES32 Forum
Are you online when trying the app?
Jackill
#12 Post by Jackill » 14 Jan 2019, 12:21
grovkillen wrote: 14 Jan 2019, 09:25 Are you online when trying the app?
Bingo!
When starting flasher with network enabled and internet connection online - it crashes always.
When I try to start it with network disabled - it starts well.
#13 Post by grovkillen » 14 Jan 2019, 13:43
Okay so I will need to fetch that error then. Thanks for the feedback! Much appreciated, new version will arrive tomorrow.
#14 Post by grovkillen » 15 Jan 2019, 14:01
Civodul
#15 Post by Civodul » 15 Jan 2019, 22:17
Hi grovkillen,
It's OK for me for new version TAG 0.04.001
Many thanx.
#16 Post by grovkillen » 16 Jan 2019, 06:10
Thanks for the info.
Users browsing this forum: Bing [Bot] and 19 guests
