I tried to erase all setting because I had a constant wifi problem with the robotDyn d1r2
even after flashing bare 4 mb minimum wifi config is retained.
but how?
how to delete everything?
Thanks T
erase all settings
Re: erase all settings
thanks
problem is, it will connect to wifi and bring up the the website.
I always have a authorization error , even if I change IP via serial console either to dhcp or static.
I changed everything
- SSID
- IP static / dhcp
So I have to set the settings back to factory without website.
Thanks Thomas
thanks
- SSID
- IP static / dhcp
Thanks Thomas
ok, i have to check serial command .....
did serial reset .
I would have expected a complete empty ESP but esp firmware still on it?
but STA is not coming .
RESET: Resetting factory defaults... using default settings
RESET: Warm boot, reset count: 0
RESET: formatting...
RESET: formatting done...
RESET: Succesful, rebooting. (you might need to press the reset button if you've justed flashed the firmware)
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
⸮U107 :
INIT : Booting version: mega-20190116 (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
108 : INIT : Warm boot #2 - Restart Reason: Software/System restart
110 : FS : Mounting...
137 : FS : Mount successful, used 75802 bytes of 957314
482 : CRC : program checksum ...OK
493 : CRC : SecuritySettings CRC ...OK
601 : INIT : Free RAM:27928
603 : INIT : I2C
603 : INIT : SPI not enabled
616 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
619 : WIFI : No valid wifi settings
621 : WIFI : Could not connect to AP!
622 : WIFI : Set WiFi to AP
1543 : WIFI : AP Mode ssid will be ESP_Easy_0 with address 192.168.4.1
2878 : WD : Uptime 0 ConnectFailures 0 FreeMem 24520
Users browsing this forum: No registered users and 130 guests
