I want to poll a gpio to see what the pin status is, how do I use publish to get the value or state of the gpio?
device nset in gpio 0 as a switch
Name: switch, Value: swi
I tried on the rules command: publish,/wemos01/gpio/0,[switch#sw1] but only shows "[switch#sw1] not the value.
Not much info in the docs (says to be added).
Any advice?
How to publish to get the value or state of the gpio?
Re: How to publish to get the value or state of the gpio?
is not what you have here:Name: switch, Value: swi
Was a typo above, I did set:
Name:switch Value:sw1
Idea was to "poll" the esp (via mqtt) at any time to return a status of the gpio pin in the esp . The esp will mqtt listen(sniff) for a "poll" and response with a publish of the gpio status.
I am just not sure with the syntax of the publish command.
Thanks,
Thanks,
Then it looks correct. Please provide all settings so I can look and see what might be the problem.
Users browsing this forum: No registered users and 43 guests
