Hello from Germany
Hello from Germany
My name is Michael, I'm from Germany and try ESPEasy on my board, but something doesn't work like it should do. So I will become a member of this forum to ask the experts what I could/should do.
My NodeMCU V3 ESP8266 ESP-12E is connected with 5 DS18B20, everything works fine, every 60 seconds the Boards get the Informations and send them with MQTT until...thats the problem until it stops without a reason. reboot doesnt work. If I disconnect the power for a few seconds, everyhing works fine again. Until the problem start again. Has anyone the same problems? What should I do.
Re: Hello from Germany
You should give us all information (settings, wiring and log etc). Hard to give you any suggestions otherwise.
But welcome!
But welcome!
Thank you.
Wiring:
Ground to Ground (Black wire from the sensors)
3.3V to the red wire from the sensors
D5 to the yellow wire from the 5 sensors
one 4,7kOhm between red and yellow
This is the Log from Now.
54816124: WD : Uptime 914 ConnectFailures 0 FreeMem 19968 WiFiStatus 3
54846124: WD : Uptime 914 ConnectFailures 0 FreeMem 19968 WiFiStatus 3
54849864: DS : Temperature: 0.00 (28-aa-a9-e8-18-13-2-72)
54849868: EVENT: Speicher_Multi#Temperature2=0.00
54849923: DS : Temperature: 0.00 (28-aa-5d-60-19-13-2-a5)
54849926: EVENT: Heizung_Vorlauf#Temperature3=0.00
54849979: DS : Temperature: 0.00 (28-aa-33-fd-18-13-2-c1)
54849983: EVENT: Außen#Temperature4=0.00
54850031: DS : Temperature: 0.00 (28-cd-4e-ce-1f-13-1-5e)
54850034: EVENT: Heizung_Ruecklauf#Temperature5=0.00
54855367: DS : Temperature: 0.00 (28-32-32-e3-1f-13-1-a9)
54855371: EVENT: Speicher_Waerme#Temperature1=0.00
54876124: WD : Uptime 915 ConnectFailures 0 FreeMem 19808 WiFiStatus 3
Wiring:
And after I disconnect and reconnect from power, everything work.
log from Now.
66126: WD : Uptime 1 ConnectFailures 0 FreeMem 19536 WiFiStatus 3
72738: DS : Temperature: 61.00 (28-32-32-e3-1f-13-1-a9)
72741: EVENT: Speicher_Waerme#Temperature1=61.00
72797: DS : Temperature: 90.00 (28-aa-a9-e8-18-13-2-72)
72801: EVENT: Speicher_Multi#Temperature2=90.00
72854: DS : Temperature: 20.00 (28-aa-5d-60-19-13-2-a5)
72857: EVENT: Heizung_Vorlauf#Temperature3=20.00
72908: DS : Temperature: 7.50 (28-aa-33-fd-18-13-2-c1)
72912: EVENT: Außen#Temperature4=7.50
72968: DS : Temperature: 20.50 (28-cd-4e-ce-1f-13-1-5e)
72972: EVENT: Heizung_Ruecklauf#Temperature5=20.50
96126: WD : Uptime 2 ConnectFailures 0 FreeMem 18496 WiFiStatus 3
log from Now.
Now I try a bigger powersupply. I don't know if it's the solution, but it's a try. So change iPhone-Charger and only for test I will use now the Mac-Book-Charger.
Yes try the better PSU.
Doesn't work.
Log Uptime 336
20166123: WD : Uptime 336 ConnectFailures 0 FreeMem 19736 WiFiStatus 3
20172737: DS : Temperature: 59.50 (28-32-32-e3-1f-13-1-a9)
20172742: EVENT: Speicher_Waerme#Temperature1=59.50
20172798: DS : Temperature: 66.00 (28-aa-a9-e8-18-13-2-72)
20172801: EVENT: Speicher_Multi#Temperature2=66.00
20172853: DS : Temperature: 20.00 (28-aa-5d-60-19-13-2-a5)
20172856: EVENT: Heizung_Vorlauf#Temperature3=20.00
20172909: DS : Temperature: 6.50 (28-aa-33-fd-18-13-2-c1)
20172912: EVENT: Außen#Temperature4=6.50
20172966: DS : Temperature: 20.00 (28-cd-4e-ce-1f-13-1-5e)
20172970: EVENT: Heizung_Ruecklauf#Temperature5=20.00
20196123: WD : Uptime 337 ConnectFailures 0 FreeMem 19736 WiFiStatus 3
20226123: WD : Uptime 337 ConnectFailures 0 FreeMem 19736 WiFiStatus 3
20232736: DS : Temperature: 0.00 (28-32-32-e3-1f-13-1-a9)
20232740: EVENT: Speicher_Waerme#Temperature1=0.00
20232795: DS : Temperature: 0.00 (28-aa-a9-e8-18-13-2-72)
20232799: EVENT: Speicher_Multi#Temperature2=0.00
20232850: DS : Temperature: 0.00 (28-aa-5d-60-19-13-2-a5)
20232853: EVENT: Heizung_Vorlauf#Temperature3=0.00
20232902: DS : Temperature: 0.00 (28-aa-33-fd-18-13-2-c1)
20232905: EVENT: Außen#Temperature4=0.00
20232961: DS : Temperature: 0.00 (28-cd-4e-ce-1f-13-1-5e)
20232964: EVENT: Heizung_Ruecklauf#Temperature5=0.00
20256134: WD : Uptime 338 ConnectFailures 0 FreeMem 18168 WiFiStatus 3
Log Uptime 336
I suggest you disconnect the sensors and attach them one at the time. Run for a while and see if it's the connection to some of them that is the problem.
sorry for the late answer. I was on tour for a few days. Great idea.... Thank you, I will try it.
