MCP23017 question
- Sasch600xt
MCP23017 question
Hello all
may i have a probably dumb question but i cant find the answere.
i need to send out 4 analog values from ESP (0-3.3V / 0-255)
I have a MCP23017 connected to ESP.
Can i do it with a MCP ?
And if yes, how would the syntax look like ?
If NO, is there a way to get 4 analog output pins working with ESP (like a "analog output port expander") ?
See ? Dumb question
Thanks for help
Sascha
See ? Dumb question
Thanks for help
Sascha
- budman1758
Re: MCP23017 question
Methinks the best way is to use an ADS1115 A-D Converter chip. MCP23017 is only for on,off or pulse stuff.
No such thing as a dumb question. Nobody falls out of their mama knowing everything.
ADS is an AD.
In this case the question is for an DA output stage.
I am also interested if anybody has the answer.
Belgium and land of ESP ... counting
- budman1758
What is the source of these values? How does the ESP get the values in the first place?
- Sasch600xt
i want to send MQTT Messages to the ESP.
like:
http://192.168.123.45/control?cmd=ANALOG_OUT,1,255
http://192.168.123.45/control?cmd=ANALOG_OUT,2,127
http://192.168.123.45/control?cmd=ANALOG_OUT,3,0
http://192.168.123.45/control?cmd=ANALOG_OUT,4,200
this sends the value to a 4ch dimmer (0-3.3volt expected)
So lets google for a ADS1115 A-D Converter chip
Is there a plugin already for ESP Easy ?
Thank you all for your Help
Sascha
like:
Sascha
- budman1758
Not sure you need the ADS1115 here as I am still a bit confused as to what the ESP is actually doing here. You say you want to send these analog values TO the ESP. I assume they then go out to a dimmer of some sort?
Maybe a picture or a diagram or schematic would be helpful.
- Sasch600xt
http command ---> ESP Easy -----> 4 times analog 0-3.3Volt out ------> 4 CH Dimmer
I see the ADS1115 is for analog INPUT, but i need to have analog OUTPUT.
- budman1758
I think what you need to do is convert PWM output to a voltage.
See this for inspiration.
https://www.instructables.com/id/Analog ... o-Voltage/
- Sasch600xt
- Sasch600xt
Now another question
i dont understand in doku:
MCPPulse,<pin>,<value>,<duration> 1,0 Pulse control on MCP23017 output pins (duration in mS, MILLIseconds)
so how would a http command look like for MCP port 1 with a pwm of 127 ( i assume value can be from 0-255) ?
Thank you so much
Sascha
Thank you so much
Sascha
- budman1758
I'm not sure the MCP23017 supports PWM. That's a question for the devs. Some of the native ESP GPIO support PWM. Might be easier to use those.
Or a dedicated PWM output chip module.
- Sasch600xt
i have a PCA9685 here and i will try one of those
- Sasch600xt
i do not get a signal out of the PCA9685 ?
It shows up after "scan for i2C device".
So i try:
http://192.168.123.45/control?cmd=PCAPWM,1,4095
and get:
"log": ": PWM 1",
"plugin": 22,
"pin": 1,
"mode": "PWM",
"state": -1
any ideas ?
Thank you for your help
So i try:
and get:
"log": ": PWM 1",
"plugin": 22,
"pin": 1,
"mode": "PWM",
"state": -1
any ideas ?
You can use this motor PWM like DA converter for convert digi to analog via i2c:
https://www.letscontrolit.com/wiki/inde ... 2#Hardware
So by TB 6612
So by TB 6612
- Sasch600xt
yes, but i have already a PCA9685 and there is a plugin for in ESP Easy.
plus budman showed a very good and very small solution to get a analog signal out of a pwm signal.
the only question right now is why does the PCA9685 not work ?
i must do something wrong here.
Thanks for help
Sascha
Thanks for help
Sascha
Users browsing this forum: Ahrefs [Bot] and 93 guests
