I just tried to determine the status of a timer.
The answer to the command:
"http://192.168.1.226/control?cmd=status,Timer=3"
was "NEXTION075: WRITE = Timer, 3".What does that mean?
Best regards
Martin
NEXTION075 : WRITE = Timer,3
- schnurzel59
Greetings Martin
Re: NEXTION075 : WRITE = Timer,3
I guess that the nextion plugin is using the "status" command?
If you are using the Nextion Touch Screen Plugin, and have oddly named the Nextion device as "STATUS", then this response would occur as a result to sending data to it. However, if you are not using the Nextion plugin, or haven't named it STATUS, then the ESP Easy software you are using is broken.
For better advice you need to provide full details to your setup. For example: hardware description, software bin file version, plugin and controller lists, browser version, etc.
BTW, I was not aware that it is possible to get a timer's status from the browser control command. Must be something new. Where did you find the details on it?
- schnurzel59
I tested different things. Just as you can test the status of a gpio with an http query, so i wanted to see what happens when you query a timer.
I had not expected to get a result. But the result had already confused me a bit. That was, however, 3 or 4 times repeatable, but never again.
Is probably just another of the absurdities of the ESPEasy software.
I also want to specifically search errors with these tests in order to be able to handle these in my programs. If everything works then I prefer
this to do without new firmware. There are new problems every time. Have already discovered some strange things in the handling of variables
and device values. Also, the syntax in the rules is not so uniformly regulated. But that's another thing. I'll write about it another time.
Martin
Martin
Greetings Martin
Users browsing this forum: Ahrefs [Bot] and 108 guests
