I compiled with only P026, P049 and P126. Via rules I publish CO2 value and Systemload to Domoticz.
I have 2 problems.
The ESP8266 (Wemos) reboots several times per day without any reason. I decoupled Vcc on several places met capacitors.
My syslog server logs error logs with the content: "EspEasy: MQTT : Ignored too big message"
Anyone any idea how to solve these bugs?
MQTT error
Re: MQTT error
A common problem for many months. Developers are still working on it.The ESP8266 (Wemos) reboots several times per day without any reason. I decoupled Vcc on several places met capacitors.
That error means that ESPEasy received an incoming MQTT that is bigger than its payload buffer (and the message has been ignored). The buffer is approx 380 bytes.My syslog server logs error logs with the content: "EspEasy: MQTT : Ignored too big message"
Re: MQTT error
Tnx Thomas for the info,
I have no idea which device sends more then 380 bytes, but will investigate.
Do you know where to change the buffer to a bigger size?
B.t.w. I removed the MQTT Controller and switch to http in a rule. No reboots so far.
Re: MQTT error
It's in Controller.inoDo you know where to change the buffer to a bigger size?
But rather than increase the buffer you should add some debug messages that help ID the offending MQTT sender. That's the area that needs help.
Users browsing this forum: Google [Bot] and 115 guests
