is it possible to define a variabe
- like : %ruleversion% = "version"
which can be used later in publish command?
I know the workaround to set a generic dummy device with event and eventvalue, but it would be easier to have a variable within rules to be used after flashing the rules .
thanks T
(solved)rules define own variable within rules
Re: rules define own variable within rules
As of the last 2-3 months you can define up to 16 internal variables.
The rule above will set variable 16 to the value 123. You can use the variables in either using this syntax:
%v16%
Or
[VAR#16]
How you want to publish the version number is then up to you.
Let,16,123
%v16%
Or
[VAR#16]
ok, that is perfect.
thanks
thanks
Re: (solved)rules define own variable within rules
also alphanumeric once?
Users browsing this forum: No registered users and 134 guests
