I am working on a project where ESP Easy is interacting with Domoticz, or the other way around. I have now managed to get information from Domoticz to ESP Easy and Domoticz to read values from devices on ESP Easy. I am using two Setpoints on Domoticz to set wanted value of the temperature using rules on ESP Easy and dzVents on Domoticz:
return {
active = true,
on = {
devices = {
'BadNede'}
execute = function(domoticz, device)
local url= 'http://10.0.0.217/control?cmd=event,Bad ... ice.state)..'' -- your IP !!!
print(url)
domoticz.openURL(url)
end}
This works as expected.
Now I want to implement a dummy switch which I want to use to indicate the status of the relays, but I don't know if this can be done by rules on ESP Easy, and if so how it should be implemented.
It is possible this is not a topic for this forum, so I cross post it on the Domoticz forum.
Best regards
Ulf
Interacting with Domoticz
Re: Interacting with Domoticz
Create dummy switch in Domoticz and take note about its IDX
In rules on ESPeasy use something like this:
Here IDX is 26
Again - all this is in discussion below my video, which you know.
SendToHTTP 192.168.1.253,8080,/json.htm?type=command¶m=switchlight&idx=26&switchcmd=On
or
SendToHTTP 192.168.1.253,8080,/json.htm?type=command¶m=switchlight&idx=26&switchcmd=Off
Here IDX is 26
on HeatingOn do
if [Rele#Switch]=0
TaskValueSet,2,1,[Variables#Counter]+1
gpio,5,1
SendToHTTP 192.168.1.253,8080,/json.htm?type=command¶m=switchlight&idx=91&switchcmd=On
on HeatingOff do
gpio,5,0
SendToHTTP 192.168.1.253,8080,/json.htm?type=command¶m=switchlight&idx=91&switchcmd=Off
I'm sorry I did bother you with the question. I had tested the syntax, and it did not work. The reason was a logical error in my Rule set. Fixed now, and works as expected!
Thanks a lot!
Thanks a lot!
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 36 guests
