Feature request - SendtoHTTP authentication
theone
#1 Post by theone » 24 Jun 2016, 11:33
Is it possible to add username and password to the SendtoHTTP command?
I would like my ESP to send ON/OFF/Toggle commands directly to my KMTronicC WEB relay board.
http://kmtronic.com/kmtronic-lan-ethern ... board.html
There is no option to remove the authentication from it.
I would like to do something like this to toggle relay 6:
http://admin:admin@192.168.2.20/relays.cgi?relay=6
Mariete
Re: Feature request - SendtoHTTP authentication
#2 Post by Mariete » 14 Feb 2017, 09:12
Did you manage to do the authenticated call?
I'm facing the same situation with SendToHTTP
DIY CO2 monitor with ESP Easy at https://emariete.com/medidor-casero-co2/
ESP Easy related info at my blog: https://emariete.com/tag/espeasy/
groovy
#3 Post by groovy » 14 Feb 2017, 09:34
Did you have a look here?
Mariete
#4 Post by Mariete » 14 Feb 2017, 09:56
Thank you.
Looks like my _C008.ino is already modified but it still doesn't work.
I'm trying to use it in a rule.
sincze
#5 Post by sincze » 20 Mar 2019, 11:14
In my rules I used to have commands like:
SendToHTTP 192.168.*.*,8080,/json.htm?type=command&param=udevice&idx=88&nvalue=0&svalue=[Liters#Liters]
RULES make my life easy and I can do whatever I want without having to create DUMMY sensors in the ESP.
However since my Domoticz machine moved to a different vlan I now have to use AUTHENTICATION.
Would it be possible to implement this with SendToHTTP somehow??
jvm1000
#7 Post by jvm1000 » 12 Dec 2020, 16:51
that works fine
MkE= is the base64 encoded username ('2A' in this example)
OVM= is the base64 encoded password ('9S' in this example)
SendToHTTP 172.19.219.230,8080,/json.htm?username=MkE=&password=OVM&type=command&param=switchlight&idx=36&switchcmd=On
thank for all you help
Users browsing this forum: Ahrefs [Bot] and 34 guests
