(solved) hardware initial setting gpio output low not working?
riker1
#1 Post by riker1 » 27 Mar 2019, 12:52
I did set hardware GPIO 0 to output low.
after reboot. checking state,
http://192.168.10.17/control?cmd=status,gpio,0
results in high 1:
"log": "",
"plugin": 1,
"pin": 0,
"mode": "input",
"state": 1
why is hardware setting ignored?
What am I doing wrong?
Thanks T
Re: hardware initial setting gpio output low not working?
#2 Post by ThomasB » 27 Mar 2019, 16:02
GPIO-0 is the special boot mode pin. https://www.letscontrolit.com/wiki/inde ... figuration
A logic low on GPIO-0 at boot initialization would create a problem. Perhaps that is why your GPIO-0 boot state setting is being ignored.
It is Ok to use it in your rules (because they run after boot is complete). But be careful to ensure that whatever you connect to it does not pull it logic low during boot.
riker1
#3 Post by riker1 » 28 Mar 2019, 08:04
ok thanks.
that is right. I forgot those limitations.
It is working for gpio 3 and within rules
Thanks T
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 82 guests
