Let's assume the version: I enable socket 1 through the app, the remaining 2.3 are disabled.
When I press the button on the slat. Slot 1 will turn off, the rest will turn on.
I would like to create a rule that will send to IDX and allow all three to be included in the button.
And that when you attach the slat, it also sent home information about the attached socket.
Actual rule:
On System#Boot do
gpio,3,0
On WIFI#Connected do
SendToHTTP 10.10.10.254,8080,/json.htm?type=command¶m=switchlight&idx=18&switchcmd=Off ### correct?
SendToHTTP 10.10.10.254,8080,/json.htm?type=command¶m=switchlight&idx=19&switchcmd=Off ### correct?
SendToHTTP 10.10.10.254,8080,/json.htm?type=command¶m=switchlight&idx=20&switchcmd=Off ### correct?
on Button1#state do
if [Relay1#state]=0 or [Relay2#state]=0 or [Relay3#state]=0
gpio,5,1
gpio,4,1
gpio,13,1
gpio,5,0
gpio,4,0
gpio,13,0
on Relay1#state do
if [Relay1#state]=0
gpio,1,1
gpio,1,0
on Relay2#state do
if [Relay3#state]=0
gpio,1,1
gpio,1,0
on Relay3#state do
if [Relay3#state]=0
gpio,1,1
gpio,1,0
GPIO 5,4,13 Relay
