In my setup (Wemos D1 / Espeasy 20190404 / BMP280), the pressure value is not published over MQTT.
In the DEVICES window, it clearly show values for Temp (14.1) Humidity (0) Pressure (1018.4), Humidity is 0 because it is a BMP280.
Looking at the log window, it shows correct values for Temp and Pressure (Humidity is not shown here).
When subscribing with MQTT tool, it only publish a correct value for Temp, Humidty = 0 but NO Pressure topic and value.
It looks like ESPEASY is publishing Humidity instead of Pressure ...
Any thoughts ?
-ben
BMP280 pressure publishing problems [solved]
Re: BMP280 pressure publishing problems
BMP do not have humidity. Only BME does.
EDIT: sorry, misread. How big is your MQTT queue? But it might be a bug.
MAX Queue Depth was at 2, after changing it to 5 it worked perfect !!
The only (minor) thing is that it also publish Humidity while the sensor doesn't have Humidity but I can live with that
Tnx !
-ben
Tnx !
-ben
Users browsing this forum: Bing [Bot] and 43 guests
