push button and http cmd value/state of button
pw444
#1 Post by pw444 » 04 May 2019, 19:18
Hya,
i would like to know if and if yes, how to change teh value of a state using rules.
I have one push button define device switch input, push button active low, pullup pn, gpio0, named pb01.
With the followin code,
// pb01   - gpio 0 - D5
// output - gpio 2 - D3
On System#Boot do
 let,1,0 // future enhancement by VAR
on pb01#value do
  if [pb01#value]=1
    GPIO,2,1
    GPIO,2,0
on pb01_on do
  GPIO,2,1
on pb01_off do
  GPIO,2,0
it works. pusing button, output is on (by devices, value 1), push again, it's off (by devices, value 0).
now, by off, by devices, value 0
using web:
http://192.168.1.5/control?cmd=event,pb01_on output in on, and by devices, value does not change, remains 0.
i push the button, nothing happens, i push it a second time, and output is off, and value by devices is ok.
Is there a way to change the value inside the rule, so either by physical button or by web - http cmd, the value reflects the action, so after using http, the state / value is correct and pushing the button it works, without having to push twice?
TIA
Re: push button and http cmd value/state of button
#2 Post by grovkillen » 04 May 2019, 19:20
For each GPIO command you should add a let command.
pw444
#3 Post by pw444 » 04 May 2019, 19:21
Thx for answering.
Just let, alone?
example, please?
#4 Post by grovkillen » 05 May 2019, 12:37
pw444
#5 Post by pw444 » 05 May 2019, 13:38
Thx for the answer.
By the examples, old way, a toggle switch (on off) is used. I'm using a push button.
" For LET commands let me get back to you on that if you still want it?", sure!
BR
#6 Post by grovkillen » 05 May 2019, 13:48
It's not a physical toggle switch. It's a virtual way of toggling.
pw444
#7 Post by pw444 » 05 May 2019, 14:04
Yes, sir, it's virtual toggle. The physical button (which exists), it's a push button.
All i want to is get rid of the need of pushing physically twice after it has been virtually toggled, when the state / value does not change.
If you can be so nice and educate me with the suggested "let" i'll really appretiate it.
By the old way, if there is also a way to have the state / value changed when virtually toggled, i'll also appretiate, as i could not find in the rules docs how to set the value of pb01 (pb01#value), like value=1 or value=0.
Thx in advance.
#8 Post by grovkillen » 05 May 2019, 16:54
Did you read the discussions I linked to?
pw444
#9 Post by pw444 » 05 May 2019, 17:02
grovkillen wrote: 05 May 2019, 16:54 Did you read the discussions I linked to?
yes, i did. and using the old way, i got it. i was asking the new way, with let, as you mentioned, and also asked.
viewtopic.php?f=4&t=6030&p=32910&hilit= ... tch#p32910
viewtopic.php?f=4&t=5771&p=31040&hilit= ... tch#p31040
viewtopic.php?f=6&t=2039&p=25350&hilit= ... tch#p25350
That's the old way. For LET commands let me get back to you on that if you still want it?
but maybe i'm not that smart, in neither post i've found how to set the pb01#value (value velue # of a device) variable to 1 or 0 using rules ;-)
#10 Post by grovkillen » 05 May 2019, 17:05
Ok good. I will get back to you on that one. I'm watching a movie with the family :)
pw444
#11 Post by pw444 » 06 May 2019, 13:02
grovkillen wrote: 05 May 2019, 17:05 Ok good. I will get back to you on that one. I'm watching a movie with the family :)
ok, thank you. look forward for the reply ;-)
pw444
#12 Post by pw444 » 07 May 2019, 14:24
#13 Post by grovkillen » 07 May 2019, 15:06
On System#Boot Do
 Let,1,0 //on boot make sure the LED is off
 GPIO,2,1 //the LED is set to off (inverted logic)
EndOn
On Button#State Do
  Event,toggleLED
EndOn
On toggleLED Do
  If [VAR#1] = 0
   Event,turnOnLED
  Else
   Event,turnOffLED
  EndIf
EndOn
On turnOnLED Do
  Let,1,1
  GPIO,2,0  //remember that this example uses onboard LED which is using inverted logic
EndOn
On turnOffLED Do
  Let,1,0
  GPIO,2,1  //remember that this example uses onboard LED which is using inverted logic
EndOn
Now you can use these three (event) commands:
toggleLED if LED is on it will be turned off, if LED is off it will be turned on
turnOnLED if LED is on it will not change, if LED is off it will be turned on
turnOffLED if LED is on it will be turned off, if LED is off it will not change
pw444
#14 Post by pw444 » 07 May 2019, 16:07
Ok, thank you.
My doubt was regarding the use of let on states.
Last sunday, i had the follwoing code:
// boots off
On System#Boot do
 let,1,0
// GPIO,2,0
on pb01#value do
   gpiotoggle,2
   if [VAR#1]=0
    let,1,1 // state on
    // publish light on
    let,1,0 // state off
    // publish light off
on pb01_on do
  GPIO,2,0
  let,1,1
  // publish light on
on pb01_off do
  GPIO,2,1
  let,1,0
on pb01sw do
  gpiotoggle,2
  if [VAR#1]=0
    let,1,1 // state on
    // publish light on
i was not understanding the let use, but your example shows it.
Thx a lot.
