(solved)send to and having same device from different esp
I am wondering if it is possible to distinguish between 2 different devices .
Have 3 devices:
connect all via UDP Port
want to display some status values on ESP1.
ESP 2 and ESP 3 having same device name.
Can they be distinguished?
Or do I need unique device names?
Have 3 devices:
Re: send to and having same device from different esp
Unique unit numbers?
sorry, no I mean,
esp1 receiving variable von both ESP2 and ESP3
device#variable names are same on esp2 und 3
How to separate those , showing them on LCD, on ESP1.
is it like:
[ESP2#device#variabe]?
Does this clarify?
T
is it like:
Does this clarify?
T
Unit Numbers are distinct.
Only same UDP Port.
but ...device names and variables ...?
You need to use the same task numbers on them all, that means you should be able to distinguish them.
thanks
but I do not understand how?
when you say, task # , this is on ESP1 (receiving)
I have a task there : lcd:
will display
but is send by both ESP 2 and ESP 3.
So how to grab the send by ESP2?
Thanks for clarification.
T
thanks
will display
WRC:[status_control#Wifi_Reconnect_Counter]
So how to grab the
T
You need to set up the recieving task/unit to be identical to the sending task/unit and have it send using the ESP Easy controller.
ok understood, thanksgrovkillen wrote: ↑21 May 2019, 14:58 You need to set up the recieving task/unit to be identical to the sending task/unit and have it send using the ESP Easy controller.
Users browsing this forum: Bing [Bot] and 62 guests
