Save data to txt
chprzemo
Save data to txt
#1 Post by chprzemo » 03 Jun 2019, 09:26
Hello everyone,
I am writing from Poland, I have been using ESPEasy in Wemos for a month, I would like to implement a program that will save data (from DS18B20) to a txt file in the internal memory of ESP. Can you help me, how to handle txt files from ESPEasy?
Re: Save data to txt
#2 Post by grovkillen » 03 Jun 2019, 09:48
"Cache controller" is your friend.
chprzemo
#3 Post by chprzemo » 03 Jun 2019, 13:50
Can you give me some bearing, for example, or documentation on how to use it?
#4 Post by grovkillen » 03 Jun 2019, 14:54
If you enable it it'll dump it to the file system and you will get it as raw memory files (find it in tools/file system). To parse it as CSV we use a JavaScript file. We're still developing it though.
chprzemo
#5 Post by chprzemo » 04 Jun 2019, 09:55
Thanks, I'll try tonight
rayE
#6 Post by rayE » 04 Jun 2019, 10:44
@ Chprzemo, can you post your findings here? This sounds very useful for posting bulk data to a cloud IOT service.
Ulisses_proj
#7 Post by Ulisses_proj » 18 Apr 2020, 15:38
grovkillen wrote:
03 Jun 2019, 14:54
I am currently trying to read the .bin file that the cache controller writes to, but have so far been unsuccessful. Would you be able to provide the JavaScript file to read the data from the .bin file? Or give a hint as to how to read the file.
Thank you!
#8 Post by TD-er » 18 Apr 2020, 15:54
Save this to a .htm file on the ESPeasy node (on file system)
<html>
<script src="https://cdn.jsdelivr.net/npm/lodash@4.17.11/lodash.min.js"></script>
<script>
const TASKS_MAX = 12;
const VARS_PER_TASK = 4;
function sleep(ms) {
  return new Promise(resolve => setTimeout(resolve, ms));
class DataParser {
    constructor(data) {
        this.view = new DataView(data);
        this.offset = 0;
        this.bitbyte = 0;
        this.bitbytepos = 7;
    pad(nr) {
        while (this.offset % nr) {
            this.offset++;
    bit(signed = false, write = false, val) {
        if (this.bitbytepos === 7) {
            if (!write) {
                this.bitbyte = this.byte();
                this.bitbytepos = 0;
            } else {
                this.byte(signed, write, this.bitbyte);
        if (!write) {
            return (this.bitbyte >> this.bitbytepos++) & 1;
        } else {
            this.bitbyte = val ? (this.bitbyte | (1 << this.bitbytepos++)) : (this.bitbyte & ~(1 << this.bitbytepos++));
    byte(signed = false, write = false, val) {
        this.pad(1);
        const fn = `${write ? 'set' : 'get'}${signed ? 'Int8' : 'Uint8'}`;
        const res = this.view[fn](this.offset, val);
        this.offset += 1;
        return res;
    int16(signed = false, write = false, val) {
        this.pad(2);
        let fn = signed ? 'Int16' : 'Uint16';
        const res =  write ? this.view[`set${fn}`](this.offset, val, true) : this.view[`get${fn}`](this.offset, true);
        this.offset += 2;
        return res;
    int32(signed = false, write = false, val) {
        this.pad(4);
        let fn = signed ? 'Int32' : 'Uint32';
        this.offset += 4;
        return res;
    float(signed = false, write = false, val) {
        this.pad(4);
        const res =  write ? this.view.setFloat32(this.offset, val, true) : this.view.getFloat32(this.offset, true);
        this.offset += 4;
        return res;
    bytes(nr, signed = false, write = false, vals) {
        const res = [];
        for (var x = 0; x < nr; x++) {
            res.push(this.byte(signed, write, vals ? vals[x] : null));
        return res;
    ints(nr, signed = false, write = false, vals) {
        const res = [];
            res.push(this.int16(signed, write, vals ? vals[x] : null));
        return res;
    longs(nr, signed = false, write = false, vals) {
        const res = [];
            res.push(this.int32(signed, write, vals ? vals[x] : null));
        return res;
    floats(nr, signed = false, write = false, vals) {
        const res = [];
            res.push(this.float(write, vals ? vals[x] : null));
        return res;
    string(nr, signed = false, write = false, val) {
        if (write) {
            for (var i = 0; i < nr; ++i) {
                var code = val.charCodeAt(i) || '\0';
                this.byte(false, true, code);
        } else {
            const res = this.bytes(nr);
            return String.fromCharCode.apply(null, res).replace(/\x00/g, '');
const parseConfig = (data, config, start) => {
    const p = new DataParser(data);
    if (start) p.offset = start;
    const result = {};
    config.map(value => {
        const prop = value.length ? value.length : value.signed;
        _.set(result, value.prop, p[value.type](prop, value.signed));
    return result;
const fileFormat = [
    [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].values`, type:'floats', length: VARS_PER_TASK  })),
    [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].timestamp`, type: 'longs', signed: false  })),
    [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].controllerIndex`, type: 'byte'  })),
    [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].taskIndex`, type: 'byte'  })),
    [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].sensorType`, type: 'byte'  })),
    [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].valueCount`, type: 'byte'  })),
    { prop: 'values', type:'floats', length: VARS_PER_TASK },
    { prop: 'timestamp', type: 'int32', signed: false },
    { prop: 'controllerIndex', type: 'byte' },
    { prop: 'taskIndex', type: 'byte' },
    { prop: 'sensorType', type: 'byte' },
    { prop: 'valueCount', type: 'byte' },
loadConfig = () => {
    return fetch('http://192.168.1.182/cache_json').then(response => response.arrayBuffer()).then(async response => {
        document.body.innerText = parseConfig(response, fileFormat);
loadConfig = async () => {
    const floatvalues = {};
    const info = await fetch('/cache_json').then(response => response.json());
	let csv = info.columns.join(';') + '\n';
	for (var j = 0; j < (VARS_PER_TASK * TASKS_MAX); j++) {
		// TODO make "unused" value configurable
		floatvalues[j] = 0;
	// TODO must also read partial files (< 24k)
	var maxFileNr = info.files.length;
	for (var filenr = 0; filenr < maxFileNr; filenr++) {
	    var elem = document.getElementById("bar");
		var width = Math.round(100.0 * (filenr / (maxFileNr - 1 )));
		elem.style.width = width + '%';
        elem.innerHTML = width * 1 + '%';
		const binary = await fetch(info.files[filenr]).then(response => response.arrayBuffer()).then(async response => {
			const samples = {};
			var arrayLength = response.byteLength / 24;
			//1000;//samples.length;
			[...Array(arrayLength)].map((x, i) => {
				samples[i] = parseConfig(response, fileFormat, 24 * i);
			// TODO Fetch number of samples.
			for (var i = 0; i < arrayLength; i++) {
			  var floatIndex = VARS_PER_TASK * samples[i].taskIndex;
			  samples[i].values.forEach(item => {
				floatvalues[floatIndex] = item;
				floatIndex++;
			  // TODO quick fix to remove damaged samples due to writing to closed files.
			  if (samples[i].timestamp > 1500000000) {
			      const utc_date = new Date(samples[i].timestamp * 1000);
				  csv += samples[i].timestamp + ';' + utc_date.toISOString() + ';' + samples[i].taskIndex;
					csv += ';' + floatvalues[j];
				  csv += '\n';
			await sleep(100); // Wait to prevent the ESPeasy node from rebooting.
//	document.body.innerText = csv;
//    document.body.innerHTML = `<a href='data:text/plain;charset=utf-8,${encodeURIComponent(csv)}' download='test.csv'>click me</a>`;
	const a = document.createElement('a');
	const aText = document.createTextNode('Download');
	a.href = window.URL.createObjectURL(new Blob([csv]), {type: 'text/csv'});
	a.download = 'test.csv';
	a.appendChild(aText);
	a.classList.add("button");
	document.getElementById("downloadLink").appendChild(a);
//	document.body.appendChild(a);
</script>
<style>
#progress {
  width: 100%;
  background-color: #ddd;
#bar {
  width: 0%;
  height: 30px;
  background-color: #4CAF50;
  text-align: center;
  line-height: 30px;
  color: white;
h1, h2 {
    font-size: 16pt;
    margin: 8px 0;
h1, h2 {
    color: #07D;
    box-sizing: border-box;
    font-family: sans-serif;
    font-size: 12pt;
    margin: 0;
    padding: 0;
.button {
    background-color: #07D;
    border: none;
    border-radius: 4px;
    color: #FFF;
    margin: 4px;
    padding: 4px 16px;
</style>
<body>
<h2>ESPeasy cache to CSV</h2>
<BR>
<button class="button" type="button" onclick="loadConfig()">Fetch cache files</button>
<div id="progress">
  <div id="bar">0%</div>
</div>
<BR>
<p id="downloadLink"></p>
</body>
</html>
Ulisses_proj
#9 Post by Ulisses_proj » 18 Apr 2020, 16:11
Excellent! Thank you, both for the quick response and the support.
Works like a charm!
#10 Post by TD-er » 18 Apr 2020, 17:04
Ulisses_proj wrote:
18 Apr 2020, 16:11
Works like a charm!
It is operational on the unit mounted in my car for about a year already.
Also used this in the Delsbo Electric event in May 2019.
Users browsing this forum: Bing [Bot] and 17 guests
