longpress action without first have the shortpress action
megamarco83
#1 Post by megamarco83 » 16 Feb 2019, 00:44
Hi i have this configuration:
2 relay: relay_kitchen and relay_bathroom
2 wall switch: wall_kitchen and wall_batroom
every relay is triggered by it's wall switch shortpress.
the wall switch are setted as pushbutton active low
the longpress is setted as active only on low
the scope is that i want that if i longpress the kitchen wall switch the bathroom relay will turn on, but without triggering the relay of kitchen.
this is my rules:
On System#Boot do    //When the ESP boots, do relay to OFF just to be sure
  gpio,13,1 //kitchen
  gpio,14,1 //bathroom
on wall_kitchen_1#Switch do
	if [sniff#kitchen]=0
	  Publish domoticz/in,{"command": "switchlight", "idx": 96, "switchcmd": "On" } // id of kitchenLight
	if [sniff#kitchen]=1
	  Publish domoticz/in,{"command": "switchlight", "idx": 96, "switchcmd": "Off" }
on wall_kitchen_1#Switch=10 do // longpress ->bathroom
	if [sniff#bathroom]=0
	  Publish domoticz/in,{"command": "switchlight", "idx": 97, "switchcmd": "On" } / id of BathroomLight
	if [sniff#bathroom]=1
	  Publish domoticz/in,{"command": "switchlight", "idx": 97, "switchcmd": "Off" }
on sniff#kitchen=1 do gpio,13,0
on sniff#kitchen=0 do gpio,13,1
on wall_bathroom_1#Switch do
	  Publish domoticz/in,{"command": "switchlight", "idx": 97, "switchcmd": "On" } // id of bathroomlight
on sniff#bathroom=1 do gpio,14,0
on sniff#bathroom=0 do gpio,14,1
if longpress bathroom relay turn on, but before relay kitchen is turned on and in a while off. How i can avoid that?
thanks
xury
Re: longpress action without first have the shortpress action
#2 Post by xury » 16 Feb 2019, 02:42
You not using a timer to determine when is a short press and when is a long.
See at rules tutorial info:
on Button#State=1 do
  timerSet,1,1
on rules#timer=1 do
 if [Button#State]=0
  //Action if button is short pressed
  //Action if button is still pressed
megamarco83
#3 Post by megamarco83 » 16 Feb 2019, 09:30
thanks, but it was an "old" way to perform the long press that you that you link
if i understand well now inside the new fw there are events for long and doubleclick:
https://espeasy.readthedocs.io/en/lates ... witch-page
Long press event: If enabled the unit will detect a long press of a button. There’s three different behaviors of the long press:
Active only on low: this means that the unit will only be triggering the long press event if the signal is low. Two different event values are used, 10 if the state goes from 0 to 1 (Switch#State=10), and 11 if the state goes from 1 to 0 (Switch#State=11).
Active only on high: same as above but only triggered on high signal.
Active on high & low: the long press will be triggered both on high and low signals
so how i can use the event in the new fw but triggering directly the longpress event without activating before the shortpress?
thanks
megamarco83
#4 Post by megamarco83 » 18 Feb 2019, 09:40
any suggestion? :-)
tobias007
#5 Post by tobias007 » 16 Jun 2019, 13:34
I have the same issue.
I tried all possible combinations to avoid a short press message before the long press activates. But it always triggers the short press first.
Any possibility to implement this?
Thanks a lot.
Kind regards. Tobias
#6 Post by grovkillen » 16 Jun 2019, 13:49
Using rules you can filter out those short presses.
tobias007
#7 Post by tobias007 » 16 Jun 2019, 16:21
Hi Grovkillen,
thanks for the quick reply. Could you provide any example?
Thanks in advance.
Tobias
anarro
#8 Post by anarro » 21 Jul 2019, 20:40
Please, any example??
anarro
#9 Post by anarro » 27 Jul 2019, 13:23
this is my final solution:
on sw1#state do
 if [sw1#state]=3
  //double click triggered!
  publish /HA/esp_papa/sw1/state,1
  timerSet,1,0
 elseif [sw1#state]=10
  //Longclick triggered!
  publish /HA/esp_mama/sw1/state,1
  timerSet,1,0
  //click triggered!
  timerSet,1,1
on rules#timer=1 do
  publish /HA/esp_papas/sw1/state,1
#10 Post by grovkillen » 27 Jul 2019, 13:30
Perfect solution *thumbs up*
rt1970
#11 Post by rt1970 » 13 Apr 2020, 20:13
It doesnt work. It will do nothing. I think the problem is: if [sw1#state]=3
I have this Code in my WEMOS D1 (one Switch and 3 LEDs: Click, Double Click and long Click)
on Taster#State do
 if [Taster#State]=3
  gpiotoggle,0
  timerSet,1,0
 elseif [Taster#State]=10
  gpiotoggle,2
  timerSet,1,0
  //click triggered!
  gpiotoggle,4
  timerSet,1,1
on rules#timer=1 do
My Logging is:
435704: SW : GPIO=5 State=0 Output value=0
435706: EVENT: Taster#State=0.00
435804: SW : GPIO=5 State=1 Output value=1
435806: EVENT: Taster#State=1.00
436104: SW : GPIO=5 State=0 Doubleclick=3
436109: EVENT: Taster#State=3.00
436704: SW : GPIO=5 State=1 Output value=1
436708: EVENT: Taster#State=1.00
441904: SW : GPIO=5 State=0 Output value=0
441906: EVENT: Taster#State=0.00
442904: SW : LongPress: GPIO= 5 State=0 Output value=10
442906: EVENT: Taster#State=10.00
Users browsing this forum: Bing [Bot] and 47 guests
