I'm trying to work out the workflow here on how ESPEasy does the MQTT thing
I'd like to send the temp reading from a DS18B20 to an MQTT broker. So in this case I'm looking to publish data from ESPEasy to my MQTT broker.
In order to do this I first have to setup a controller correct? I chose the OpenHAB MQTT based on what I read in the Wiki.
Next I need to setup the DS18B20 on the device tab.
After this is all done, do I still need to create a rule to actually publish the data? I ask this because at this point I'm not able to get any data published to my broker and before I start clicking buttons and checking check boxes I wanted to understand if a rule is required.
If a rule is required, could I please get a link to the format of the command? I did some research in the wiki and was not able to find how the command should be formatted.
Thank you
(SOLVED) Trying to understand how ESPEasy works with MQTT
Re: Trying to understand how ESPEasy works with MQTT
OpenHab MQTT works well with ESPEasy. But first test your OpenHAB MQTT controller and confirm it is working correctly.In order to do this I first have to setup a controller correct? I chose the OpenHAB MQTT based on what I read in the Wiki.
If all you want to do is MQTT the temperature then enable the DS18B20 plugin's Send To Controller function. Whenever ther temperature changes the new value will be sent by MQTT; Unchanged temperature is not sent, but a rule can do it if that kind of behavior is needed.Next I need to setup the DS18B20 on the device tab. After this is all done, do I still need to create a rule to actually publish the data?
For additional advice you should post screenshots of your MQTT and device settings.
Thank you for your reply. I just got this working after some messing around. I just wasn't sure where the rules part came into play so I appreciate the post so I could leave that out of the testing.
I now I have two devices publishing to my cloudmqtt broker. The system uptime and a button push
You're welcome. It's good to know you got it working.
Users browsing this forum: Google [Bot] and 120 guests
