Solved! Since update endless feedback loop of a switching command between ESP EASY and Domoticz
Ruprecht
#1 Post by Ruprecht » 28 Jun 2019, 17:25
In our laundry drying room in the basement i have an automatic control of the fan with a sensor (BME280). This is done by a rule in ESP EASY, which turns on a fan automatically when the humidity is above 49%. This switch state of this fan is visible on Domoticz and the fan could be switched also over Domoticz manually. This worked so far as desired by me.
Today I've made an update to ESP EASY Mega 20190626. Now is there a feedback loop between ESP EASY and Domoticz. As soon as I switch on or off the fan manually via Domoticz, ESP EASY immediately returns this switching command as a new switching state to Domoticz and ESP EASY immediately returns this switching state as a new switching state to Domoticz and so on. Also, an on/off delay brought no improvement.
How do I get back the previous state of the controller where my manual command does not trigger an endless feedback loop?
On System#Boot do
  PCFGPIO,1,0
  PCFGPIO,2,0
  PCFGPIO,3,0
  PCFGPIO,4,0
  PCFGPIO,5,0
  PCFGPIO,6,0
  PCFGPIO,7,0
  PCFGPIO,8,0
  timerSet,1,60
On Rules#Timer=1 do
  //Taupunkt aussen   (Berechnung unter 50% Feuchte falsch!)
 TaskValueSet,9,1,[LAussenTemp#Temp]-(100-[LAussenTemp#Feuchte])/5
  //Taupunkt innen      (Berechnung unter 50% Feuchte falsch!)
 TaskValueSet,9,2,[HeizTFD#Temp]-(100-[HeizTFD#Feuchte])/5
  //Lüfter an
  if [HeizLueft#LuefterH]=0 and [HeizTFD#Feuchte]>48 and [Taupunkt#TaupAussen]<[Taupunkt#TaupInnen]
    PCFGPIO,1,1
  //Lüfter aus
  if [HeizLueft#LuefterH]=1 and [HeizTFD#Feuchte]<44
   PCFGPIO,1,0
  if [HeizLueft#LuefterH]=1 and [Taupunkt#TaupAussen]>[Taupunkt#TaupInnen]
   PCFGPIO,1,0
 timerSet,1,300
2019-06-28 16:25:42.289 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:42.779 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:43.290 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:43.812 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:43.281 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:43.803 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:44.445 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:44.894 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:44.436 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:44.885 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:45.382 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:45.887 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:45.373 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:45.879 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:46.500 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:46.492 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:47.211 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:47.685 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:47.202 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:47.676 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:48.183 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:48.695 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:48.174 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:48.686 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:49.309 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:49.786 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:49.297 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:49.777 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:50.290 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:50.785 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:50.281 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:50.776 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:51.855 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:51.846 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:52.338 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:52.792 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:52.329 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:52.783 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:53.322 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:53.803 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:53.313 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:53.798 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:54.517 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:54.988 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:54.508 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:54.979 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:55.507 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:55.985 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:55.498 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:55.976 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:56.488 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:56.949 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:56.479 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:56.940 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:57.410 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:57.930 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:57.401 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:57.921 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:58.395 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:58.880 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:58.386 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:58.870 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:59.410 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:59.883 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:25:59.406 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:25:59.878 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:26:00.806 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:00.797 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:26:01.296 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:01.758 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:01.287 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:26:01.749 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:26:02.284 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:02.774 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:02.275 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:26:02.765 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:26:03.284 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:03.757 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:03.275 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:26:03.748 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
2019-06-28 16:26:04.287 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:04.779 (Heizung) Light/Switch (Lüfter Heizraum (>49% Feuchte))
2019-06-28 16:26:04.278 Status: User: Admin initiated a switch command (40/Lüfter Heizraum (>49% Feuchte)/Off)
Re: Since update endless feedback loop of a switching command between ESP EASY and Domoticz
#2 Post by ThomasB » 28 Jun 2019, 18:01
Try disabling the "Send to Controller" option in the PCF8574 plugin.
Ruprecht
#3 Post by Ruprecht » 28 Jun 2019, 18:39
That would eliminate my feedback problem, but then I would lose the status display of the fan in Domoticz.
Currently I am solving the feedback problem by deleting the on/off actions in Domoticz. But now the manual control of the fan is not possible.
#4 Post by ThomasB » 28 Jun 2019, 18:59
The status data can be sent to Domoticz by your ESPEasy rules (use the publish command).
Ruprecht
#5 Post by Ruprecht » 02 Jul 2019, 16:54
Again, the same result. It makes no difference whether the status is sent directly from the EspEasy device or Publish Command. Again, Domoticz responds with endless repeating this command.
In the meantime I believe that´s not a mistake but a feature which only did not occur with the old version mega-20180818. Presumably, the mistake sits in front of the screen.
How to program a switch with Domoticz + EspEasy which also displays the actual state if e.g. in the meantime a rule changes the switching state?
kimot
#6 Post by kimot » 02 Jul 2019, 20:14
Disable "send to controller"
In Domoticz On / Off action use your pcfgpio commands.
And in your rules send json htttp command about switch state to Domoticz.
Then if you switch from Domoticz - it sets gpio and do not send back to Domoticz.
If you set switch by rules in ESPeasy- it sets gpio, send status to Domoticz by json http call and Domoticz immediately sends the same gpio command to ESPeasy
and in this time loop ends.
Ruprecht
#7 Post by Ruprecht » 03 Jul 2019, 16:58
Thanks for the "thinking help". Now everything works again without loop:
Domoticz
action on:
http://192.168.178.81/control?cmd=event,luefterein
action off:
http://192.168.178.81/control?cmd=event,luefteraus
EspEasy
Send to controller: disabled on this device
Rules:
On System#Boot do
  PCFGPIO,1,0
  PCFGPIO,2,0
  PCFGPIO,3,0
  PCFGPIO,4,0
  PCFGPIO,5,0
  PCFGPIO,6,0
  PCFGPIO,7,0
  PCFGPIO,8,0
  timerSet,1,60
  SendToHTTP 192.168.178.19,8080,/json.htm?type=command&param=udevice&idx=40&nvalue=0
On Rules#Timer=1 do
  //Lüfter an
    PCFGPIO,1,1
    SendToHTTP 192.168.178.19,8080,/json.htm?type=command&param=udevice&idx=40&nvalue=1
  //Lüfter aus
  if [HeizLueft#LuefterH]=1 and [HeizTFD#Feuchte]<43
    PCFGPIO,1,0
    PCFGPIO,1,0
 timerSet,1,300
On luefterein do
    PCFGPIO,1,1
On luefteraus do
    PCFGPIO,1,0
voyo
Re: Solved! Since update endless feedback loop of a switching command between ESP EASY and Domoticz
#8 Post by voyo » 17 Dec 2019, 19:19
I have same issue. And I managed to "fix" it same way.
However - this is not a solution , this is workaround !
This way, makes having domoticz controller completely unless and pointless, same with functionality of
"Send Boot state" and "Send to Controller"
Is this erroneous behaviour fixed correctly in newer firmware versions ?
#9 Post by TD-er » 18 Dec 2019, 09:32
What was the correct working version?
And maybe either one of you can formulate what may be wrong here?
I don't know enough of what Domoticz does here (but I do have it installed here for simple testing), so please give me some pointers.
If we have some proper idea of where to look, then it would be best to have a GitHub issue for it, since finding back issues here on the forum is next to impossible.
voyo
#10 Post by voyo » 18 Dec 2019, 22:01
version that I used -
ESP_Easy_mega-20181003_normal_ESP8266_1024.bin
and mega-20190607 (self build, from github)
Both are behaving same, I wanted to try newer version, but looks like it doesn't have much sens if you are not aware of this bug actually...
So, in my case its behaves like this -
Domoticz (newest stable version) is added as controller (HTTP type)
on switch and/or relay tab (a device) there are options to configure data acquisition - "Send to Controller" and IDX.
When this is enabled (acquisition, and domoticz controller) no matter whether it is switch or related relay, it creates a continuous loop of flip-flop:
espeasy is sending status of the device to domoticz, domoticz is somehow switching device to opposite position, and back and forth.
What I think: probably espeasy is actually sending to domoticz not status update of the device, but command to change device status.
Maybe there was some change in domoticz API in the meantime , some time ago ? I'm not sure.
I didn't have time yet to enable some debug and confirm if this is like I think it is.
When I completely disable/remove domoticz controller and data acquisition in espeasy, and instead of this I just use rules with SendToHTTP - it works OK.
But well - this is not the way it should be. Domoticz integration is pointless.
This is rule set that I have (which is my workaround):
On System#Boot do
  timerSet,1,59
On Rules#Timer=1 do
    SendToHTTP 10.0.0.113,8080,/json.htm?type=command&param=udevice&idx=36&nvalue=0
on button#switch do
  if [button#switch]=1
   gpio,14,1
   gpio,14,0
   SendToHTTP 10.0.0.113,8080,/json.htm?type=command&param=udevice&idx=36&nvalue=1
#11 Post by TD-er » 19 Dec 2019, 14:24
It is possible Domoticz has changed something, but it may also be something in ESPEasy has changed in relation to the GPIO handling.
Actually some GPIO handling stuff did change around December last year.
