i press one button on my samsung or Pioneer remote, i see a sequenz for this single button of the remote.
also i would like to send the "code" with the http-request/push template, not only the float ? "value" (because the code is shorter).
do i have to configure something more?
is this normal, that the remote sends one code for the button-press, and another arbitrary for release?
the "press"-code seems the same, the "release"-code seems to change..
this is two time the on/off=press/release sequence of the same button (info) on my samsung remote:
Feb 2 21:21:26 ESP Unit: 0 : HTTP : closing connection
PRESS -- Feb 2 21:21:32 ESP Unit: 0 : IR : Code e0e0f807
Feb 2 21:21:32 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:21:32 ESP Unit: 0 : /esp01?device=sw13?device=¶m=IR&value=3772839936.00
Feb 2 21:21:32 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:21:32 ESP Unit: 0 : IR : Code a6240345
Feb 2 21:21:32 ESP Unit: 0 : HTTP : Delay 1000 ms
Feb 2 21:21:33 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:21:33 ESP Unit: 0 : /esp01?device=sw13?device=¶m=IR&value=2787377920.00
Feb 2 21:21:33 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:21:36 ESP Unit: 0 : DS : Temperature: 23.87 (28-ff-dd-f0-4c-4-0-3a)
Feb 2 21:21:36 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:21:36 ESP Unit: 0 : /esp01?device=sw13?device=¶m=Temperature&value=23.87
Feb 2 21:21:36 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:21:46 ESP Unit: 0 : DS : Temperature: 23.94 (28-ff-dd-f0-4c-4-0-3a)
Feb 2 21:21:46 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:21:46 ESP Unit: 0 : /esp01?device=sw13?device=¶m=Temperature&value=23.94
Feb 2 21:21:46 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:21:46 ESP Unit: 0 : WD : Uptime 6 ConnectFailures 0 FreeMem 24888
Feb 2 21:21:46 ESP Unit: 0 : UDP : Send Sysinfo message
PRESS -- Feb 2 21:21:49 ESP Unit: 0 : IR : Code e0e0f807
Feb 2 21:21:49 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:21:49 ESP Unit: 0 : /esp01?device=sw13?device=¶m=IR&value=3772839936.00
Feb 2 21:21:50 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:21:50 ESP Unit: 0 : IR : Code 49f3e444
Feb 2 21:21:50 ESP Unit: 0 : HTTP : Delay 1000 ms
Feb 2 21:21:50 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:21:50 ESP Unit: 0 : /esp01?device=sw13?device=¶m=IR&value=1240720512.00
Feb 2 21:21:51 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:21:56 ESP Unit: 0 : DS : Temperature: 23.87 (28-ff-dd-f0-4c-4-0-3a)
Feb 2 21:21:56 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:21:56 ESP Unit: 0 : /esp01?device=sw13?device=¶m=Temperature&value=23.87
Feb 2 21:21:56 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:23:56 ESP Unit: 0 : HTTP : closing connection
PRESS -- Feb 2 21:24:00 ESP Unit: 0 : IR : Code fc200794
Feb 2 21:24:00 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:24:00 ESP Unit: 0 : /esp01?device=sw13?device=¶m=IR&value=4229957632.00
Feb 2 21:24:01 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:24:01 ESP Unit: 0 : IR : Code 8a87cad4
Feb 2 21:24:01 ESP Unit: 0 : HTTP : Delay 1000 ms
Feb 2 21:24:01 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:24:01 ESP Unit: 0 : /esp01?device=sw13?device=¶m=IR&value=2324155136.00
Feb 2 21:24:02 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:24:06 ESP Unit: 0 : DS : Temperature: 23.87 (28-ff-dd-f0-4c-4-0-3a)
Feb 2 21:24:06 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:24:06 ESP Unit: 0 : /esp01?device=sw13?device=¶m=Temperature&value=23.87
Feb 2 21:24:06 ESP Unit: 0 : HTTP : closing connection
PRESS -- Feb 2 21:24:13 ESP Unit: 0 : IR : Code fc200794
Feb 2 21:24:13 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:24:13 ESP Unit: 0 : /esp01?device=sw13?device=¶m=IR&value=4229957632.00
Feb 2 21:24:13 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:24:13 ESP Unit: 0 : IR : Code 105f71ef
Feb 2 21:24:13 ESP Unit: 0 : HTTP : Delay 1000 ms
Feb 2 21:24:14 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:24:14 ESP Unit: 0 : /esp01?device=sw13?device=¶m=IR&value=274690528.00
Feb 2 21:24:14 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:24:16 ESP Unit: 0 : DS : Temperature: 23.94 (28-ff-dd-f0-4c-4-0-3a)
Feb 2 21:24:16 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb 2 21:24:16 ESP Unit: 0 : /esp01?device=sw13?device=¶m=Temperature&value=23.94
Feb 2 21:24:16 ESP Unit: 0 : HTTP : closing connection
Feb 2 21:24:16 ESP Unit: 0 : WD : Uptime 8 ConnectFailures 0 FreeMem 24888
Feb 2 21:24:16 ESP Unit: 0 : UDP : Send Sysinfo message
