Create rules for 8 buttons/relays + LCD display
rudloffl
#1 Post by rudloffl » 20 Jul 2019, 16:45
Hello all,
Still working on my sprinkler system. The esp8266 is connected to 2 PCF8574 (relays and buttons), 1 LCD display and thermometer (GPIO).
I tried to link the button pressing acting on the relay:
- one pression turns the selected relay on
- one other pression turns off the relay
- A pression on a different zone turns on the selected relay and turns off the previous relay
- I must update the display
- I'm using 2 dummy variable (quad) to publish the relay status to the home automation system
- I will use timer to turn off the relays automatically
My problem is I can't get the rules to run properly, most button press (if tight with a rule) results in a crash. Calling the event via http works OK.
Can someone review my code and guide to some improvments/solutions:
- Is the syntax OK ?
- What can be wrong on the hardware side, am i asking too much to the esp ?
- Catch more errors in the log ?
- How deep can I nest the events (I'm coming from python...)
- I noticed sometime that IF/THEN/ELSE with %eventvalues% behaves not as expected
- Anything else...
On System#Boot Do
event,alloff
endOn
//Button actions
on button8#State Do
if [button8#State]=1
Event,button=8,5
EndOn
on button7#State Do
if [button7#State]=1
Event,button=7,10
EndOn
//General feature called
on button Do
if [VAR#%eventvalue1%]=0
event,relayon=%eventvalue1%,%eventvalue2%
event,relayoff=%eventvalue1%
//Turns everything down
On alloff Do
Let,16,0
event,relayoff=1
event,relayoff=2
event,relayoff=3
event,relayoff=4
event,relayoff=5
event,relayoff=6
event,relayoff=7
event,relayoff=8
EndOn
On relayoff Do //turns off the relay number
let,%eventvalue%,0 // Sets the variable
pcfgpio,%eventvalue%,1
timerSet,%eventvalue%,0
On relayon Do //Turns on the relay number for defined number of secondes
let,%eventvalue%,1
let,16,1
pcfgpio,%eventvalue1%,0
timerSet,%eventvalue1%,%eventvalue2%
On WiFi#Connected Do
LCD,1,1,%ip%
EndOn
Any guidance will be appreciated
rudloffl
Re: Cretae rules for 8 buttons/relays + LCD display
#2 Post by rudloffl » 20 Jul 2019, 16:50
A picture of the beast for some context
Re: Create rules for 8 buttons/relays + LCD display
#3 Post by ThomasB » 20 Jul 2019, 20:13
For better review of the installation you should post a screenshot of the devices page.
rudloffl
#4 Post by rudloffl » 20 Jul 2019, 21:12
Let me know if you need anything else
Capture d’écran du 2019-07-20 14-11-28.png (220.48 KiB) Viewed 6704 times
rudloffl
#5 Post by rudloffl » 20 Jul 2019, 21:58
I think the problem comes from my schematic (the short test I did over the HTTP are ok), see the code below.
What's the best way to connect a switch to the pcf8574 (where to put the resistor) ?
On System#Boot Do
event,alloff
endOn
on button8#State Do
Event,button=8,5
EndOn
on button7#State Do
Event,button=7,10
EndOn
on button Do
if [VAR#16]=1
event,alloff
On alloff Do
Let,16,0
event,relayoff=1
event,relayoff=2
event,relayoff=3
event,relayoff=4
event,relayoff=5
event,relayoff=6
event,relayoff=7
event,relayoff=8
EndOn
On relayoff Do
let,%eventvalue%,0
let,16,0
//timerSet,%eventvalue%,0
On relayon Do
let,%eventvalue1%,1
let,16,1
LCD,1,1,%ip%
EndOn
#6 Post by ThomasB » 21 Jul 2019, 00:22
Some comments that deserve your attention:
1.
AFAIK, that trickery is not allowed. The wiki says to copy the %eventvalue% to a dummy. Then act on the dummy value.
2.
let,%eventvalue%,0
Just to be cautionary, this might not be doing what you want. It would clear system variables (%v1% - %v8%), not the dummy's in your event list.
3.
Timers are being initialized, but no event routines have been defined. Either remove the timer code or create the eight timer event routines.
If you observe random ESP resets when a relay is turned On or Off then it could be due to transient voltage spikes from the relay coil. To confirm if resets are related to the relay operation then test the device with the relay module disconnected.
Log message detail can be changed at Tools=>Advanced=>Log Settings
Good question. I've never nested more than a couple deep using the MEGA releases, so I can't say how much nesting is possible before the stack goes wacky. Nesting success probably depends on the firmware version and the plugins that are being used.
Copy %eventvalues% to dummy vars (or system vars), then use the copies in your if/then/else.
The PCF8574 has a weak pull-up resistors built into each I/O pin, so an external pull-up is rarely needed. Your push button switch should ground the input when it is pressed.
rudloffl
#7 Post by rudloffl » 21 Jul 2019, 01:10
Thanks for your feedback Thomas, it helps a lot.
I will update the code and keep you informed.
Users browsing this forum: Bing [Bot] and 1 guest
