I am wondering if I can store a variable persistent in a flash part maybe config sections ?
thanks T
store a variable persistent in config section
Re: store a variable persistent in config section
Yes and no. Nothing which is set dynamically will survive a boot. BUT you can use a MQTT broker and MQTT import to fetch the value from there (if you have the retained setting checked).
But we're discussing a external flash (EEPROM) which could be used.
I'd like to re-activate this question: for quite a few of my ESP's I programmed myself, I had the necessity to store values that would survive even long periods of no power.
Either because I do not want to enable WiFi or simply because I can't.
Yes, I know, memory cells are wearing out, like all hardware and us human beings, too.
But a change from time to time shouldn't really harm the devices.
Maybe there's a chance to get this feature - or is it already available - and I have browsed only those messages were it wasn't?
As ESP Easy already uses persistent storage, it shouldn't be a big effort ... credentials, drivers, rules, all seem to be pretty persistent. Maybe a small change in the device's section or a few new system variables would do?
We're discussing implementing external EEPROM as well as a command to store to flash.
I was just looking at the same thing as I need to be able to save threshold values from time to time that need to survive a cold re-boot. At the moment I am trying an instance of regulator (PO21) where I can use the setlevel and getlevel commands. I couldn't find any reference to any other method. Prior to this I was using the MQTT method but this needs to be stand alone with no MQTT broker within reach.
Currently, using P021, the Level plugin, is the easiest way of storing and retrieving a value that'll survive a cold boot/power down. Just be aware that storing the value (too) often will wear out the flash storage.
Users browsing this forum: Google [Bot] and 122 guests
