Hi all
i use a ESP Board to Masure Temp, Humidity and Air pressure.
The Place to use a Power Supply is not a Good Place. The sun shines directly on the ESP board in the morning. A good Place is without Power.
Use a power bank from you and can share with me experience how long it lasts before it needs to be loaded!!
Christoph
ESP Board and Power via Battery
- dynamicdave
Re: ESP Board and Power via Akku
What's an Akku ????
Is it possible to put the ESP board in the shade and power it from a solar panel ???
One of my students has made a solar-powered weather station using a Wemos D1 Mini (ESP8266 running ESP-Easy).
He puts the board to sleep for 15-minutes (to save energy), then when it wakes up it takes some measurements and publishes them to Node-RED via MQTT, then goes to sleep.
If you want to try running it off of a powerbank then the time it will last depends on the mAh capacity of the powerbank.
Before he decided on using a solar panel he tried a powerbank and it only lasted 2 or 3 days before it needed charging.
Hope this helps.
PS: I can send you links to the solar-powered weather station if you are interested.
Hope this helps.
An "Akku" is probably German for "battery".
If heat, or temperature in general, is an issue. Then you should for sure not start using batteries.
That's a fire hazard waiting to happen.
You've probably seen temperature protection kicking in on a smart phone or car navigation. Those are there for a very good reason.
Re: ESP Board and Power via Battery
still, common in German is a battery but when saying 'Akku' (Akkumulator) we mean a rechargeable one.
@ dynamicdave: I woud like to see your links for the solar-powered weather station, especially for the rules.
- dynamicdave
Here's the link to the project on Discourse Node-RED.
https://discourse.nodered.org/t/solar-p ... n/12499/73
The project was split into six managable stages.
I hope you find this useful.
In Dutch we also use "accu" for rechargeable ones.
But sadly the word "battery" and "accu" are very often mixed in conversations in Dutch.
Users browsing this forum: Ahrefs [Bot] and 5 guests
