Get PWM value in any way
darkchris90
#1 Post by darkchris90 » 27 Aug 2019, 19:30
is it possible to get the current PWM status in the version 20190817? I need it for fhem. In some early versions it was in the state variable but now there is only 0,1,-1 and sometimes -2.
Where can I change the source code to get the value? I changed the code on my own and tried to modify the globalMapPortStatus directly or with the function savePortStatus. I prepared a struct which has the PWM value in the state and the output variable, but it doesnt work. I also changed the type of state to uint16_t like in the older versions.
Re: Get PWM value in any way
#2 Post by grovkillen » 27 Aug 2019, 20:00
I use a custom event and send the wanted value, which I store as in internal variable as well as setting the pwm.
So conclusion, you cannot get the value any other way currently.
darkchris90
#3 Post by darkchris90 » 27 Aug 2019, 20:43
Good evening,
thank you for the fast answering. Can you explain the custom event and how to use it?
#4 Post by grovkillen » 28 Aug 2019, 07:34
Using rules you create an event using the event command.
https://espeasy.readthedocs.io/en/lates ... Rules.html
darkchris90
#5 Post by darkchris90 » 28 Aug 2019, 20:55
Ah ok, I thought you talked about something in the code, because of the internal variable. I will try it. Thank you!
Users browsing this forum: Google [Bot] and 12 guests
