MQTT Topics/Entrys help
hi together
can someone explain me why i have this entrys in the mqtt instance of iobroker.
i can't get the solution.
i want to check the value of a io input of a wemos with espeasy on it.
see the att. picture
many thanks
pat
many thanks
pat
Re: MQTT Topics/Entrys help
The LWT you mean?
thats the other question....
why are entries with LWT in the mqtt broker, but on the espeasy i didn't fill it out...
So what is the first problem?
Ok
Why the LWT entries there?
Have you restarted the unit with these settings?
Yes, i have several times restart the device. But always this entries
If you test to add something to the topic and messages, save, remove the topics and messages, save again.
i remove the topics in iobroker and change the GPIO on the Wemos.
The Entrys in iobroker are as follow:
so i think it's ok.
when i now reboot the ESP, i habe the following entrys:
How can i place the topic inside the STATE topic? Why is there a new entry "mqtt"?
i think it's better also inside the "mqtt.0"
thanks
pat
so i think it's ok.
thanks
pat
What version are you using?
i think you mean the esp:
mega-20190830
thanks
pat
mega-20190830
thanks
pat
Then open an issue on GitHub.
ok i will try this...(don't know how... ) we will see
thanks
pat
thanks
pat
