I have a lipo battery connected to a ldo 3.3v regulator that is powering my esp8266.
This works fine however I want to monitor the 3.3v and then detect when it just starts to drop out which will indicate that the battery is getting too low.
I am using the vcc bin, I added "analog internal" as a device but it reports a measurement of "-1"
I have nothing connected to a0
What am I doing wrong?
Thanks for any help
battery vcc measure problem
Re: battery vcc measure problem
Shouldn't you use VIN?
The VCC build allows the "system info" plugin to report the VCC.
The analog input (ADC) plugin cannot be used with the VCC build.
This one has bitten me too last week
And yes this should be changed
