4x20 LCD display, change names of day of week
mackowiakp
#1 Post by mackowiakp » 13 Sep 2019, 19:34
I try to display name on day of week in my language. Because of that I use such rule:
On UpdateDisplay Do
 if %sysyear% > 2000
  Let,1,0
  Let,2,%sysweekday%
  if %v2% = 1
   LCD,1,1,%systm_hm% Niedz %sysday%/%sysmonth_0%/%sysyears%
  if %v2% = 2
   LCD,1,1,%systm_hm% Pon. %sysday%/%sysmonth_0%/%sysyears%
  if %v2% = 3
   LCD,1,1,%systm_hm% Wt. %sysday%/%sysmonth_0%/%sysyears%
  if %v2% = 4
   LCD,1,1,%systm_hm% Sr. %sysday%/%sysmonth_0%/%sysyears%
  if %v2% = 5
   LCD,1,1,%systm_hm% Czw. %sysday%/%sysmonth_0%/%sysyears%
  if %v2% = 6
   LCD,1,1,%systm_hm% Pt. %sysday%/%sysmonth_0%/%sysyears%
  if %v2% = 7
   LCD,1,1,%systm_hm% Sob. %sysday%/%sysmonth_0%/%sysyears%
  Let,1,1
 Endif
EndOn
But it does not work. Does anybody has an idea why?
Re: 4x20 LCD display, change names of day of week
#2 Post by TD-er » 13 Sep 2019, 19:37
That's a lot of endif statements.
Have you tried with just one layer?
So many endif statements looks like it may be quite a number of levels deep, but the else statement tells it should be all in the same level.
mackowiakp
#3 Post by mackowiakp » 13 Sep 2019, 19:45
OK,then what do you suggest? I don't really know how to do it in the same level.
#4 Post by TD-er » 13 Sep 2019, 19:50
Well, let's summon the Rules master @Grovkillen then :)
mackowiakp
#5 Post by mackowiakp » 13 Sep 2019, 19:56
OK. I sent him PM.
#6 Post by grovkillen » 13 Sep 2019, 22:17
Nested if's aren't allowed. And %variable% isn't always treated as a float but as a string and try to always use the [VAR#n] syntax to make it transfer into a float.
So.... try this instead:
On UpdateDisplay Do
  Let,2,%sysweekday%
  if [VAR#2] = 1
  EndIf
  if [VAR#2] = 2
  EndIf
  if [VAR#2] = 3
  Endif
  if [VAR#2] = 4
  EndIf
  if [VAR#2] = 5
  EndIf
  if [VAR#2] = 6
  EndIf
  if [VAR#2] = 7
  Endif
EndOn
mackowiakp
#7 Post by mackowiakp » 14 Sep 2019, 06:45
Thanks @grovkillen ! Works as it should work. But I think about little improvement of this code. Bit complicated procedure of if/else statements is done every minute. I mean complicated because of limited processor capabilities. In fact running such procedure is necessary only after boot and first NTP sync and at midnight. Then LCD command executed every minute should have syntax something like this:
LCD,1,1,%systm_hm% %day_of_week_name% %sysday%/%sysmonth_0%/%sysyears%
So my question is. Is it possible to assign text string to any user variable and use it in LCD command instead of explicit text string?
#8 Post by grovkillen » 14 Sep 2019, 07:03
No strings are allowed, only floats. You may want to ask for an implementation to convert an integer to day/month which would be the nicest way about it.
mackowiakp
#9 Post by mackowiakp » 14 Sep 2019, 07:07
OK. Well, everything has its limits.
#10 Post by grovkillen » 14 Sep 2019, 09:00
You could store the day number at the end of each if and look at it first thing. If it's the same value you don't need to check all the ifs. That way over once per day the unit has to go through them all.
mackowiakp
#11 Post by mackowiakp » 14 Sep 2019, 09:18
Good idea !
#12 Post by grovkillen » 14 Sep 2019, 09:19
So if the value is not the same, send it to a custom event and have all the ifs there.
