I have a problem with one module Sonoff-Basic.
Prior to that, he worked great for two years, but now, when connected to any WiFi network, it begins to reboot.
In access point mode, it works great.
I tried different versions of the MEGA firmware.
On third-party firmware it works fine.
Here is what issues in UART:
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
╙U65 :
INIT : Booting version: mega-20191028 (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
66 : INIT : Free RAM:33488
67 : INIT : Warm boot #2 Last Task: Background Task - Restart Reason: Hardware Watchdog
69 : FS : Mounting...
94 : FS : Mount successful, used 75802 bytes of 957314
478 : CRC : program checksum ...OK
515 : CRC : SecuritySettings CRC ...OK
622 : INIT : Free RAM:30368
623 : INIT : I2C
624 : INIT : SPI not enabled
719 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
825 : WIFI : Set WiFi to STA
857 : WIFI : Connecting wifiku attempt #0
2508 : WD : Uptime 0 ConnectFailures 0 FreeMem 26312 WiFiStatus 6
4940 : WIFI : Connected! AP: wifiku (50:FF:20:00:63:D6) Ch: 2 Duration: 3869 ms
5158 : WIFI : DHCP IP: 192.168.1.10 (ESP-Easy-0) GW: 192.168.1.1 SN: 255.255.255.0 duration: 337 ms
5163 : Webserver: start
5166 : firstLoopConnectionsEstablished
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
╙U64 :
65 : INIT : Free RAM:33488
66 : INIT : Warm boot #3 Last Task: Background Task - Restart Reason: Hardware Watchdog
68 : FS : Mounting...
93 : FS : Mount successful, used 75802 bytes of 957314
477 : CRC : program checksum ...OK
514 : CRC : SecuritySettings CRC ...OK
621 : INIT : Free RAM:30368
622 : INIT : I2C
623 : INIT : SPI not enabled
718 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
824 : WIFI : Set WiFi to STA
856 : WIFI : Connecting wifiku attempt #0
2507 : WD : Uptime 0 ConnectFailures 0 FreeMem 26312 WiFiStatus 6
4827 : WIFI : Connected! AP: wifiku (50:FF:20:00:63:D6) Ch: 2 Duration: 3869 ms
5043 : WIFI : DHCP IP: 192.168.1.10 (ESP-Easy-0) GW: 192.168.1.1 SN: 255.255.255.0 duration: 304 ms
5049 : Webserver: start
5051 : firstLoopConnectionsEstablished
