[Solved] Trying to use MQTT to control a servo
dynamicdave
#1 Post by dynamicdave » 09 Nov 2019, 20:41
I'm trying to use MQTT (from Node-RED) to control a servo - not working.
The topic in the MQTT-Out node in NR is.... node68/servo/1/14 with a msg.payload of 120
The on-board blue LEDon the Wemos flashes to indicate a transfer has taken place, just seems the command is not understood.
However, if I use HTTP, as follows it works (which indicates the wiring is correct and the servo is fine).
http://192.168.1.68/control?cmd=servo,1,14,120
Any suggestions as to what I'm doing wrong?
Is my syntax correct?
The FW I'm using is... ESP_Easy_mega-20191104_normal_ESP8266_4M1M.bin on a Wemos D1 Mini.
dynamicdave
[Solved] Re: Trying to use MQTT to control a servo
#2 Post by dynamicdave » 09 Nov 2019, 21:13
With some help from a friend I've got it working.
The MQTT topic should be... node68/cmd
And the payload should be... servo,1,14,120 (to move to 120 degrees)
