I2C Scan shows this [0x3C PCF8574A OLED]
where as in the previous version (ESPEasy_R120) which i used it showed properly as [0x3C OLED SSD1306]
Should i use this plugin??
https://github.com/letscontrolit/ESPEas ... 3_OLED.ino
Please help me out with this issue
{"System":{
"Build":20104,
"Git Build":"mega-20191108",
"System Libraries":"ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support",
"Plugins":46,
"Plugin description":" [Normal]",
"Local Time":"2019-11-22 19:27:52",
"Unit Number":0,
"Unit Name":"AmientMeter",
"Uptime":2,
"Last Boot Cause":"Manual reboot",
"Reset Reason":"Software/System restart",
"Load":22.20,
"Load LC":3032,
"CPU Eco Mode":"false",
"Heap Max Free Block":15992,
"Heap Fragmentation":15,
"Free RAM":18744
"WiFi":{
"Hostname":"THBmeter-0",
"IP Config":"Static",
"IP Address":"192.168.1.100",
"IP Subnet":"255.255.255.0",
"Gateway":"192.168.1.1",
"STA MAC":"84:F3:EB:4B:9D:7D",
"DNS 1":"8.8.8.8",
"DNS 2":"(IP unset)",
"SSID":"Northern Lights",
"BSSID":"C4:71:54:BE:5F:18",
"Channel":10,
"Connected msec":110795,
"Last Disconnect Reason":1,
"Last Disconnect Reason str":"(1) Unspecified",
"Number Reconnects":0,
"Force WiFi B/G":"false",
"Restart WiFi Lost Conn":"false",
"Force WiFi No Sleep":"false",
"Periodical send Gratuitous ARP":"false",
"Connection Failure Threshold":0,
"RSSI":-43
"Sensors":[
"TaskValues": [
{"ValueNumber":1,
"Name":"Temperature",
"NrDecimals":2,
"Value":31.62
{"ValueNumber":2,
"Name":"Humidity",
"NrDecimals":2,
"Value":75.16
{"ValueNumber":3,
"Name":"Pressure",
"NrDecimals":2,
"Value":1011.80
"DataAcquisition": [
{"Controller":1,
"IDX":0,
"Enabled":"false"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":5,
"Type":"Environment - BMx280",
"TaskName":"bme280",
"TaskDeviceNumber":28,
"TaskEnabled":"true",
"TaskNumber":1
{"Controller":1,
"IDX":0,
"Enabled":"false"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":5,
"Type":"Display - OLED SSD1306",
"TaskName":"THBmeter",
"TaskDeviceNumber":23,
"TaskNumber":2
"TTL":5000
